BIKELAND > FORUMS > ZX-14.com > Thread: After market Shift light??? NEW TOPIC NEW POLL POST REPLY
posted January 22, 2007 01:40 PM
What are you other drag racers using for a shift light??Anything out there that plug and play ... I need one bad because i can't even see that factory little shift light....
kawpower
Mr kawasaki 2 you!
posted January 22, 2007 02:56 PM
MSD l.e.d shift lite 3 wire hookup as easy as u can get , a few of us have them on our 14's they work great and they are small.
posted January 22, 2007 03:19 PM        Edited By: smokinZX14 on 22 Jan 2007 15:20
Thanks kawpower- Where do you hook the tack led to ?? Do you have a part number for that shift light ? Thanks Smokin..
KAWABUSAKID
Fast as my $$ will take me
posted January 22, 2007 03:26 PM        Edited By: KAWABUSAKID on 22 Jan 2007 15:28
im running a raptor led shift light ,3 wire hook up also...around $90 ,love mine ,...1 wire to chassis ground,1 wire to odd colored wire on #1 coil,1 wire to a ignition hot,....i have done 3 around here,no complaints..http://www.raptorperformance.com/
  Ignore this member    Click here to visit KAWABUSAKID's homepage.
smiddy1
posted January 22, 2007 03:33 PM
Raptor all the way.
Get on the line and drop it!
The Nitrous Advice Forum
posted January 22, 2007 03:36 PM
Odd colored wire on # 1 coil?? how oddly colored ? A little more info please ...Thanks Smokin..
KAWABUSAKID
posted January 22, 2007 03:41 PM
all the coils have 1 wire that is the same color,which should be red,and the other wire on each coil is differnt colors"meaning odd"
posted January 22, 2007 03:43 PM
Ok got it ....Thanks....Smokin..
KAWABUSAKID
posted January 22, 2007 03:44 PM
not a problem,anytime,...Lee..
ZXLNT
posted January 22, 2007 03:50 PM
Raptor shift light !!!
ninja14
posted January 22, 2007 04:08 PM
It's the "odd" white and red wire.......... :-)
I have a raptor, but they are not "weather proof"
KAWABUSAKID
posted January 22, 2007 04:14 PM        Edited By: KAWABUSAKID on 22 Jan 2007 16:15
that's it,.....mine is mounted directly on top of the odometer,in front of me....w/velcro strip attached to the plastic mount that comes w/it......it is out of the weather like that
posted January 22, 2007 04:23 PM
Never tried drag racing in the rain..If i did the shift light would be the last thing i was worried about ...lol...
KAWABUSAKID
posted January 22, 2007 04:58 PM
Yep...lol
Big_T_11
posted January 22, 2007 05:33 PM
Did you try setting the light to the Blinking mode? I can notice the blinking better than the solid setting. Also you might could tap into the shift light wire and mount your own L.E.D. Just a thought. Or tap into the wire for the light and make an autoshift out of it, activate your shifter for you.
ninja14
posted January 22, 2007 06:06 PM
Mine is mounted between the dash and windscreen poined up. Since my windscreen is painted on both sides it reflects up nicely into the covered area.
ninja14
posted January 22, 2007 06:08 PM        Edited By: ninja14 on 22 Jan 2007 18:09
There is already a shifter for bikes, but I think against the rules mostly.....
posted January 22, 2007 06:17 PM
i use the one the bike came with, doh
posted January 22, 2007 06:21 PM        Edited By: smokinZX14 on 22 Jan 2007 18:21
lol try looking at the factory shift light on a 8.80 pass ...lol....
zx12mark
posted January 22, 2007 10:12 PM
DYNA WITH THE SHIFT MINDER.ONLY THE BEST FOR MY 12
SteddyTeddy
posted January 23, 2007 08:56 AM
Dyna going on my bike now. I've been running a cheapie, but no more. You get what you pay for.
kawpower
Mr kawasaki 2 you!
posted January 23, 2007 11:02 AM
Smokin it is the red wire up front where the stick coil harness plugs into the main harness.
kawpower
Mr kawasaki 2 you!
posted January 23, 2007 11:17 AM
The part number is 8963 for msd lite.
blackbullet76
posted January 23, 2007 11:30 AM
I haven't raced mine yet, but I just set my factory one so it blinks instead of just coming on. Maybe I will be able to see it.
shane661
posted January 23, 2007 11:31 AM
Are aftermarket lights programmable, so that you can set a different shift point for each gear?
0.23210096359253 seconds processing time
