BIKELAND > FORUMS > ZX-14.com > Thread: Blue Discs? NEW TOPIC NEW POLL POST REPLY
spongebob
posted January 04, 2007 09:45 AM
Blue Discs?
After a few laps on the track where I had to brake from 260+ to 80 at the end of the straights, I noticed the brake lever going soft. Back in the pits, my discs had turned blue too.
Anyone else experienced this?
posted January 04, 2007 09:51 AM
sounds like you heat treated them, i have never raced mine on a closed course, but i haven't heard of or had any brake failures, even the mags had great things to say about the brakes
Tool man
posted January 04, 2007 09:53 AM
Yup... the blueing was only superfical though, it went away on my next ride. No soft lever.
Try using the brakes less = higher cornering speeds :P and more grins :d
The banks are failing..
The banks are failing...
Invest in Ammo
blackbullet76
posted January 04, 2007 10:25 AM
That heat could hurt your fluid. You might want to change it out to dot 5 if you do alot of track days.
phytrax
posted January 04, 2007 10:45 AM
I've noticed some issues with soft brakes also. I have a 1/4 mile strip by my house that I run for testing purposes. I go from 0-120 and back to 0 in 1/4 mile frequently. After about 3 passes in each direction I notice the brakes get soft. They still seem to have full stopping power but I have to pull the front brake in a lot more than usual before I start to feel it. After 10 min of normal riding they come back. I know it's a heat issue, but could someone explain this a little better? Is the fluid boiling, making air pockets? Rotors never get red or anything and I'm really not braking all that hard.
KX450F - kickstand
>>> MySpace --CLICK-- <<<
posted January 04, 2007 12:10 PM
+1
and decreased lap times!
spongebob
posted January 05, 2007 12:38 AM
Well, maybe I'll try swapping to dot 5 or dot 5.1 brake fluid, see if it helps.
Oh yes, the clutch seems to go soft after several laps too. Goes back to normal after it cools down.
And you can only brake so little after a mile long straight. The rear ABS was kicking in all the way, so i didn't bother to touch the rear brakes, letting the front take all the abuse
posted January 05, 2007 05:49 AM
You guys need steel brades brake lines with dot 5 fluid...
phytrax, you will still get brake fade from abusing your brakes like that !!!...All your going to accomplish by doing that is warped rotors costing you over $500...
phytrax
posted January 05, 2007 06:24 AM
I really don't feel like I'm abusing them that hard. I don't do more than 5 or 6 runs at a time normally, 3 in each direction. I usually make a slow U-turn at the end of each one also, to allow some cooling time. I feel like I'm applying less than hall of the braking that I could apply on most runs. I've heard of people taking the stock brakes to a racetrack, that's got to be a LOT more braking in 4 laps than what I'm doing. One guy got warped rotors, I remember, but it was attributed to use of race tires, not racing.
KX450F - kickstand
spongebob
posted January 05, 2007 06:50 AM
I take care to warm up my brakes carefully before giving them a good squeeze, I usually take two warmup laps to warmup the tyres and brakes first.
Oh yea, braided hoses are out of the question, I'm riding the ABS model, and there are like a zillion brake hoses running around the bike..
No complaints though, the bike is fantastic on the track.
posted January 05, 2007 09:17 AM
phytrax, the 1/4 mile track we run here it gives us enough room to slow down without hardly applying the brakes. might want to try and save em and let the motor clow you down.
posted January 05, 2007 09:23 AM
or borrow a parachute
Tool man
posted January 05, 2007 09:35 AM
Or... just sit up, your chest is about 3ft across :P
Invest in Ammo
spongebob
posted January 05, 2007 06:42 PM
Sorry, syntax error.
posted January 06, 2007 09:36 AM
what bike is that beside of the 14....ZZR1200?
posted January 06, 2007 10:42 AM
zzr1200...
0.31237697601318 seconds processing time
