BIKELAND > FORUMS > ZX-14.com > Thread: Muzzy Slip-on or Full NEW TOPIC NEW POLL POST REPLY
fas550
posted January 03, 2007 06:32 AM
What is the difference? NOT talking about the Megaphone here.
What is the difference between the Slip-on vs the full system?
I believe the full system has one muffler but the slip-on has two; given that are the Canisters the same for both systems?
Anyone had both and can comment on performance for each (I don't suppose for one second anyone has dyno with slip-on and dyno with full exhaust system?
Frank
BobC
posted January 03, 2007 07:08 AM
Hi Frank,
A full system will usually produce more power when correctly set up and saves weight, maybe 30lbs or more. It's the more expensive option too. My 14 also runs cooler with it's TiForce system.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
Tool man
posted January 03, 2007 07:16 AM
About 10 - 15 hp and aprox. 30 -35 lbs in weight for a full system. The full system is HEAVY the cans weight about 15 -20 apeice. so if you go with just slip ons you will get some saving there.
The stock collector has a catalist in it. It is also beefy, I went with a Brock's Street Meg. and Pc3 which he is very good at supplying maps for, depending on what set up you have. (Flies in or out ect.) Muzzy also will suppy a map for his pipe but his choices are more limited.
The banks are failing..
The banks are failing...
Invest in Ammo
zrx4me
posted January 03, 2007 07:23 AM
I believe the stock system has the cats in the cans not the collector.slip-ons will eliminate them.
bishopzx12
posted January 03, 2007 08:33 AM
Frankie let me know what you decide i might be willing to depart with my muzzy full system. I have the full stainles with titanium can. Ben on the bike since June of 06. thinking of going sidewinder myself
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
posted January 03, 2007 09:04 AM
Full system all the way!
Tool man
posted January 03, 2007 10:09 AM
Nope it is that little round ball at the bottom of the collector, find a cut a way pic and look.
Invest in Ammo
MasterBlaster
posted January 03, 2007 10:51 AM
There are cats in the base of the stock mufflers. I bandsawed mine off at the base of the mufflers to reuse the mid pipes, and there is a Catalyst in each muffler at the bottom end. That is why the stockers are so heavy....TB
zrx4me
posted January 03, 2007 11:57 AM
that round ball is not the cat.
0.23620295524597 seconds processing time
