BIKELAND > FORUMS > ZX-14.com > Thread: Why PC the fly out bike? NEW TOPIC NEW POLL POST REPLY
heavenlyride
posted December 04, 2006 07:37 PM
I pulled the flys yesterday. Not hard thanks to the boards feedback. I put the beast back togehter. Again not hard.
I then rode the beast. It pulled much harder and I saw no issues with the mapping. I hit it hard, very hard, but not for a long time. I rode up and down the road and a few twists but that was it.
Given the easy idle and power, why do I need the PC and Map. It seems it worked fine when I put the thing together.
I am using the stock pipes.
I have ordered from the guys in New York, very nice and helpful on the by and by, but do I need it?
Thanks.
Bently
2012 14r In Blue and no Mods!
posted December 04, 2006 07:40 PM
SOme say you do some say you don't, I rode mine for 500 miles with the flies out no pc and Mine seems fine. I have a pc now cause i went with brocks exhaust.
Tool man
posted December 04, 2006 07:42 PM
Readhttp://www.bikeland.org/board/viewthread.php?FID=27&TID=24810&set_time=
Bike runs much too lean at 3500, A/F ratio's 17 to 1 Not good for pistons uless you want to see thru them :P
The banks are failing..
The banks are failing...
Invest in Ammo
Bently
posted December 04, 2006 07:48 PM
Other peiople have dynoed with flies out and no pc and did not see that lean of a condition.
Tool man
posted December 04, 2006 08:01 PM
Ok I had not heard that, is it the pipe and fly combo that makes it run so lean ??
Invest in Ammo
heavenlyride
posted December 04, 2006 08:21 PM
Mine is stock and it was faster than stink. I loved it.
I asked on the site and bought it to be safe. But no intent to remove the pipes.
How do you get the PC in that tight spot??
BlackMagic14
posted December 04, 2006 11:32 PM
I put my PC under the windshield total 15 minute install time
BobC
posted December 05, 2006 02:18 AM
If there's any doubt about running too lean at lower rev's with flies out, take it to your nearest dyno' and get them to do a run with the gas probe in the exhaust. Shouldn't cost much and you can then make a decision about PC or no PC. A lot cheaper than a holed piston.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
the blue mule
posted December 05, 2006 04:14 AM
well do what you want, but my bike had a lean condition down low that was terrible for my approximate 900-1000ft above sea level elavation. We had to add 30% more fuel down low.
there was a terrible spike at around 3000k rpm? it's been awhile since I had it done
perhaps you should call a reputalbe shop and ask!!!
smitherscustons.com is where mine was done.
posted December 05, 2006 11:31 AM
"there was a terrible spike at around 3000k rpm? it's been awhile since I had it done"
3000k rpm man you are spinnin hard
countersteer
Didn't read the owners manual
posted December 05, 2006 03:44 PM
+1
but i think you should keep running it hard without a map- i wanna see what happens.
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
heavenlyride
posted December 05, 2006 08:16 PM
Damn countersteer, that is funny. I have the pc coming. I plan to run it. It just did not fell odd at all when I ran it.
I got the map that was done by the paint named company out of NY. Not expensive for the significantly faster bike.
I was just curious about it.
Still the notion of keeping it running to see what happens is funny.
posted December 06, 2006 10:43 AM
Its OK to name the company!
Was it Cycle Paint and Metal?
he's a site sponsor see...
http://www.bikeland.org/sponsors.php
nightmare
ACP Racing
posted December 06, 2006 11:06 AM
there is a guy telling me that I need to remove the flies and use a tre at the same time.
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
countersteer
posted December 06, 2006 02:02 PM
http://www.bikeland.org/board/viewthread.php?FID=27&TID=27089
Scott
heavenlyride
posted December 07, 2006 06:48 PM
YES IT WAS CYCLE PAINT AND METAL!!
I just could not recall the name. i had a very good exerience with them! high rec. for enthusists like them!!
heavenlyride
posted December 11, 2006 05:10 PM
I saw the map from Cycle paint and metal. It does have a richening in the lower range. Good job on their part. It does take some out at the higher levels.
I need to wait to get the bike loaded with the Map. Damn rain. 70 degree weather and wet. What a dragggg.
blackbullet76
posted December 29, 2006 05:30 AM
So even with a commander installed with premade map, it will still run lean with the flys out?
phytrax
posted December 29, 2006 09:38 AM
He doesn't know what he's talking about, just pull the flies and get a PC, you'll have an amazing transformation for $300.
KX450F - kickstand
>>> MySpace --CLICK-- <<<
blackbullet76
posted December 29, 2006 04:01 PM        Edited By: blackbullet76 on 29 Dec 2006 16:02
Will any map thats made for just slip-ons with flys out be ok for me to run? D&D don't have a map yet.
posted December 29, 2006 05:39 PM
sounds like a good probability that a slip on map would work
blackbullet76
posted December 29, 2006 06:12 PM
So I wouldn't need one that has the flys out?
dcm 21
posted December 29, 2006 07:03 PM
I just manually turned up the fuel to full on the low and mid ranges..it runs great!
fastestbusaaround
I eat Fish...
posted December 29, 2006 07:44 PM
BB76...do you have a Brock setup? If you do, you can get a flyless map from him...
FYYFF!!!
blackbullet76
posted December 29, 2006 07:51 PM
dcm 21, you turned them all the way up? What's your milage like at cruising speeds, say like on the interstate.
fastestbusaaround, nope, just D&D slip-ons. Still have factory header.
0.23698806762695 seconds processing time
