BIKELAND > FORUMS > ZX-14.com > Thread: So what does the speedo key off of?? NEW TOPIC NEW POLL POST REPLY
The Blue Mule
posted November 23, 2006 06:11 AM
I was looking at Texas mile stuff and saw a zx-14 had competed and wondered what is done to let the bike stretch its legs a bit,lol.
http://www.texasmile.com/documents/TEXASMILETOPSPEEDS_007.xls
CaptainZX14
posted November 23, 2006 06:58 AM
If in doubt, Gas it!
The Blue mule
posted November 23, 2006 07:17 AM
what am I doing wrong????
CaptainZX14
posted November 23, 2006 07:45 AM
To create a URL link, you need to put the tags around the URL:
[ url ]www.yourURLhere.com[ /url ]
Just remove the spaces in the tags to make it work.
CaptainZX14
posted November 23, 2006 07:52 AM
The engine sprocket cover has a speed sensor attached to it, I think that it picks it off of the sprocket nut. So, if you change your gearing, it throws off the speedo calibration. I hope this was what you were asking?
INTIMIDA2OR
RED rider!
posted November 23, 2006 03:12 PM
I thought it was just me when my speedo was closer to being accurate when comparing to my gps after putting a 190/55 on .
My speedo was 10mph off stock , but now it's about 5 mph off .
It would be a similar effect like a sprocket change in that case effecting the speedo.
'06 Passion Red ZX-14
*Lee*
BobC
posted November 24, 2006 01:37 AM
Do a search for all the threads about Speedo Healer.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
zxlnt
posted November 24, 2006 03:27 AM
I wonder how hard it would be to re-fit the speedo sensor to sense something driven off the front wheel. No more problems when re-gearing.
BobC
posted November 24, 2006 05:24 AM        Edited By: BobC on 24 Nov 2006 05:25
.........Or even off the rear wheel, it would be possible but you'd still have a problem with calibration. The wheels rotate 0.415 times with every revolution of the gearbox output shaft on standard gearing, so you would still need something like a speedo healer to re-calibrate. It would be easier to just use the SH on it's own.
Stock wheelbase
Phytrax
posted November 24, 2006 05:57 AM        Edited By: Phytrax on 24 Nov 2006 05:58
True, but I think what he means is you would not have to change the settings every time you change a sprocket. I don't know how helpful that would really be since most people only change sprockets once or twice.
You should also be aware that running the speedo off of the tire may cause problems with the gear indicator. On the other hand, it may get around the problems with the gear indicator. I think you would have to set the speedohealer to +240% for that to work, but that assumes the same amount of ticks per revolution as the sprocket, which may not be the case. I don't think it's even possible to set the speedohealer to +240%.
KX450F - kickstand
>>> MySpace --CLICK-- <<<
0.47812581062317 seconds processing time
