BIKELAND > FORUMS > ZX-14.com > Thread: valve cover leak NEW TOPIC NEW POLL POST REPLY
shawnski
posted November 20, 2006 10:17 AM
valve cover leak
hey guys, as you know some of us have valve cover leak from left side including myself.
on friday i had a chance to clean up the area very good with degreaser with removing the side fairing. rode saturday and sunday ( beautiful weather out here) put about 400 miles on the bike and NO MORE LEAK. i am hoping that problem went away and don't have to do any warranty work. just want to let you all know.
CaptainZX14
posted November 20, 2006 01:03 PM
Great ro hear that. If I get a leak, I will try the same.
If in doubt, Gas it!
vegasdude
posted November 20, 2006 01:28 PM
Did you check your oil?
shawnski
posted November 20, 2006 02:25 PM
oil is half way on the little glass indicator now. i think when i change the oil 1200 miles ago, it might have been more than half. i don't think that has anything to do with it, does it?
Vegasdude
posted November 21, 2006 11:15 AM
No oil = no leak...............just checking
shawnski
posted November 21, 2006 12:07 PM        Edited By: shawnski on 21 Nov 2006 12:07
that is a good one vegasdude.
ZREXER
posted November 21, 2006 02:27 PM
When your British bike quit dripping oil, it was a sign it was time to add some more!
shawnski
posted November 21, 2006 02:47 PM
time to get a new one!
blitzkrieg
Road kill = Free lunch.
posted November 21, 2006 07:38 PM
Let me give you some advice?
The three channel valve cover gaskets KAW uses (if the 14 is like the 12) are on/off.
They are almost always slightly over-torqued on the left and right banks and properly torqued in the center.
They compress when torqued and do not reseal well. Oh yeah - $40 too.
IF your 14 valve cover gasket is leaking, I would:
1) Buy a new gasket
2) Clean the valve cover (and more importantly gasket channel) with degreaser
3) Run a skim coat of RTV over both sides of the new gasket before reinstalling
4) Reinstall with meticulous attention to torque. I use a 1/4 drive socket and two fingers.
If the 14's valve cover bolts are like the 12's, they are a torque flange design and will only tighten down so far, period. This is to keep idiots from warping the cover but can also result in snapped bolts for ape's, and leaks for reused gaskets.
It's easy to fix, but you have to be diligent in your repair.
zeexman
posted November 24, 2006 05:21 PM
They come with a one year unlimited mileage warranty. Take it to the dealer and have them fix it.
shawnski
posted November 25, 2006 01:55 PM
i am trying to avoid to do any warranty work at dealer if possible, it is very painful process.
i KNOW i have warranty on the bike.
posted November 25, 2006 02:06 PM
take it in, they fix it , how hard is that?,unless you bought it from spider monkeys......
posted November 27, 2006 07:15 AM
My 14 went in twice for this problem. I posted the solution details (to include part #'s) in this thread:
http://www.bikeland.org/board/viewthread.php?FID=27&TID=26799&set_time=
shawnski
posted November 27, 2006 08:05 AM
i am glad to see your problem is fixed. mine still doing good, no leak anymore. i put another 250 miles on it this holiday weekend. still good.
posted November 27, 2006 08:30 AM
Kewl beans
0.22403192520142 seconds processing time
