BIKELAND > FORUMS > ZX-14.com > Thread: installing pistons NEW TOPIC NEW POLL POST REPLY
aliveagain
posted November 15, 2006 03:25 PM
installing pistons
just a stupid question,but how are they installed on a motor where you have to split the cases? Do you have to drop the rods and pistons down the cylinder or slide all 4 pistons in while mating the 2 cases?
posted November 15, 2006 04:00 PM
Let me go check my service manual
posted November 15, 2006 04:07 PM
You have to first split the crankcase halves, then remove the connecting rod big end caps, pull the crankshaft and then pull the piston up out of the cylinder head side.
lucky14
posted November 15, 2006 04:18 PM
Well..................that sounds easy enough.................
chavcat
posted November 15, 2006 04:51 PM
Same as a sandard car block assembly!
ninja14
posted November 15, 2006 04:53 PM
Score one point for the 'busa on that....damn :-(
Don't know why Kawi did it this way............
aliveagain
posted November 15, 2006 07:28 PM
I'm just trying to remember if I could have done that withe the twelve.I thought the rod big end was too wide.I guess there is a plus for assembly on the 14.Being able to do one at a time instead of pairs.
aliveagain
posted November 15, 2006 07:29 PM
Can the case be split while still in the frame?
Tool man
posted November 15, 2006 07:32 PM
Maybe with an axe ?? I dont' think so
The banks are failing..
The banks are failing...
Invest in Ammo
ninja12
posted November 15, 2006 08:57 PM
You can do it this way on the 12,
put all 4 pistons in the cyclinder and push them down to contact crank 1 at a time.
fastestbusaaround
I eat Fish...
posted November 16, 2006 04:45 AM
Yer the Toolman...yer supposed to know all about tools...
Did you vote for GUNNY?:P
FYYFF!!!
0.22912907600403 seconds processing time
