BIKELAND > FORUMS > ZX-14.com > Thread: trickle charge question NEW TOPIC NEW POLL POST REPLY
lietoome
posted November 03, 2006 06:41 AM
I'm planning on rotating my battery charger between the 12 and the 14 this winter. Is 2amps too much charge for winter storage? 2 amp is the lowest setting on my charger. The reason i ask is because I was looking at the 'battery tender' and its less than 1 amp. Will a 2 amp charger hurt the battery over an extended period?
thanks for the advice
jeff
earl b
posted November 03, 2006 06:43 AM
Once the battery reaches a full charge state, the battery tender has a circuit within it that senses whether it needs to comes on or not. You can leave it on as long as you want with no problem
posted November 03, 2006 07:05 AM
He don't have a battery tender. He's using a regular battery charger.
I'd just buck up and buy a battery tender. You can get a gang charger ($$$) or just swap it between bikes like you plan on doing with your regular charger.
MATTZ14
posted November 03, 2006 07:42 AM
You don't want to use your charger. Buy a float charger designed to do more then battery then you can leave them hoked up without messing up the batteries. They are cheap compared to buying a battery let alone 2.
Later days, better lays
07 BLACK ZX14 Getting customized waiting for the white stuff to go away
06 BLACK ZX14 GONE Recall was a little late.
GUNNER
posted November 03, 2006 07:54 AM
Jeff one tender and a couple sets of pig tails is all you need.. Move it every week or two and you'll be fine.
zx11_12
posted November 03, 2006 11:22 AM
Battery Tender Jr is cheap. I just bought 2 for $25 each. I have 3 bikes in the garage (already had 1 Jr.) and it's really nice to not have to remember to switch it every few days.
The pigtails are really handy too compared to having to access the battery everytime you want to hook/unhook the charger. Every time I park any of the bikes, I just plug the Tender into the pigtail and forget it until the next ride.
  Ignore this member    Click here to visit ZX11_12's homepage. Click here to send ZX11_12 an AIM message.
lietoome
posted November 03, 2006 11:23 AM
thanks for the input, I AASumed that when I bought this one it would work fine. I'll be using the battery tender this winter. The charger I have now does kick down to standby when the battery reaches full charge. I'm guessing the smallest amperage possible is going to be the best way to go. The bat-tender is .75 amps.
thanks again
jeff
extremelean
posted November 03, 2006 01:10 PM
exactly what charger do you have......If it goes into standby...It may already have a float feature built in.
Float usually means that when the battery drops below a certain voltage, the charger senses it and pumps up the charge rate until that optimum voltage is reached again....then back to float....either no amps. low amps or off.
blitzkrieg
Road kill = Free lunch.
posted November 03, 2006 02:43 PM
Yep, thats what mine does (it's a pretty good charger).
You throw it on two amps and when it hits green it stops charging. I just do that once every 3 weeks on a Saturday on both bikes and all is well.
zerMATT
posted November 05, 2006 05:30 PM
It sounds like your other charger would work... as long as it truly does go into a standby state. If that's the case, you should see the word "automatic" somewhere on it. If it doesn't claim to be automatic, don't use it for long periods. The Tender Jr. is really the way to go though... those little things are wonderful!
Otis
Captain Kickstand
posted November 06, 2006 07:20 AM
I just have one tender and keep my 3 batteries (ZX12, ZX10 and Riding Mower) on my workbench in my basement. During the winter I will just go down and switch the tender to another battery every once and a while. No big deal. And Tenders are cheap nowadays.
TeamSpeed
posted November 06, 2006 08:38 PM        Edited By: TeamSpeed on 6 Nov 2006 20:45
Walmart has the black and decker 2amp float chargers (made by vector, part number vec080bd). It comes with the pig tails as well, and the lighter plug and alligator clips all have the same pigtail. Pretty nice set up for.... wait for it.......wait....... $17!
Just picked one up this evening, along with the Compaq laptop for $400 no rebates (ati video, cd burner, 512mb ram, 60gb, wireless, etc). Nice laptop for the students in the family as well as the PC3 software, all 3 walmarts in the area sold out today, was able to reserve one. (http://www.walmart.com/catalog/product.do?product_id=5238476)
Amazon has the same battery charger for $30.
0.27644300460815 seconds processing time
