BIKELAND > FORUMS > ZX-14.com > Thread: Full exhaust install complexity NEW TOPIC NEW POLL POST REPLY
Phytrax
posted October 28, 2006 11:55 AM
I'm leaning toward getting the Brock Gen3 instead of slip ons, but can anyone tell me about how much work is involved if I do it myself. 2 hrs? More importantly, do I have to weld or cut anything to install a full system?
I mentioned in another post that I was concerned about my Corbin bags fitting properly. Does Brocks pipe come up any higher than the stock pipes? I don't see the width being a problem. I guess the lateral position of the top of the pipe would be important though. Any info?
Oh, and thanks for all the help already. I've learned an ungodly amount just browsing through this forum for 3 weeks or so. I wish the search feature was a little more robust, though. Maybe I wouldn't have to ask so many questions.
KX450F - kickstand
>>> MySpace --CLICK-- <<<
raptor14
posted October 28, 2006 12:59 PM
Exhaust install is a piece of cake. Here's the instructions that I wrote for the Gen 3 but it should apply to most aftermarket 4-2-1 systems.
http://www.bikeland.org/board/viewthread.php?FID=27&TID=26027
Phytrax
posted October 28, 2006 01:50 PM        Edited By: Phytrax on 28 Oct 2006 14:52
Awesome writeup Raptor. Sounds like a bit of a job but very straight forward. Thanks.
I was looking at that writeup on the flies removal too. If I drop a screw will the primaries catch it or do I have major issues then?
KX450F - kickstand
Stalwart
posted October 28, 2006 02:00 PM        Edited By: Stalwart on 28 Oct 2006 15:02
The primaries will indeed catch the screws and a small magnet makes retrieving them easy. Just DO NOT touch the throttle!
BTW, having the pipes ceramic coated makes the pipe install more difficult but not unmanageable with the above instructions.
Stuart
Ridin' the Trump train.
fastestbusaaround
I eat Fish...
posted October 28, 2006 03:14 PM
If you use a big long screwdriver, the screws come out easy...and take Stalwart's advice...get a pickup magnet. I heard some idiot on ZX14NINJA.com dropped the screw into the intake right down below the primaries...LOL, I don't know how he did that...but he wasn't able to get it out (seriously)...
If you're worried, get some black friction (hockey) tape and wrap the throttle to the bracket with it so it doesn't turn...simple...
FYYFF!!!
Phytrax
posted October 28, 2006 03:22 PM
I work on computers a lot and I drop screws all the time with magnetic screwdrivers, so I'd prefer to take every precaution possible. I'm not sure what throttle you are talking about wrapping exactly, but I should be able to tape the butterflies to the inside of throttle body(proper terminology?). Maybe it'll make more sense once I get the tank off.
Does Brock have a map for flies out with the stock exhaust? May hold off on the Gen3 since I'm strapped for cash.
KX450F - kickstand
countersteer
Didn't read the owners manual
posted October 28, 2006 06:34 PM        Edited By: countersteer on 28 Oct 2006 19:40
the screws actually were a small pain in the ass on mine- a little tighter than expected and started stripping a bit but no problems - waited until i got to bills shop (zx1kr) to remove them, then immediately went onto the dyno for tuning with stock exhaust
phytrax- bill has a map available and has power commanders preloaded with it for no flies+stock exhaust - you should give him a call, the map he made is PERFECT his number is 631-580-1301
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
Phytrax
posted October 28, 2006 10:30 PM
Thanks a lot. I'm gonna bookmark this until I get back on the beach. I guess Brock will give me an updated map if I buy his exhaust later on.
KX450F - kickstand
phytrax
posted December 24, 2006 09:25 AM
One of the screws in my flies was a nightmare. I had to hammer a screw driver into it several times. Even tried recutting the grooves in the head with a sharpened screwdriver which helped some. I tried 5 or 6 different heads for my screwdriver. Finally found my standard, plain ole screwdriver and it fit perfect into the new notches and was able to unscrew it. Tapping the screwdriver into the head a bit the first time with a hammer DEFINITELY helps. Wish I'd done that from the start.
KX450F - kickstand
posted December 24, 2006 09:42 AM
You sure seem to be fond of using hammers when you work on bikes!
phytrax
posted December 24, 2006 09:13 PM
Not fond, just seems like I can't avoid it, or afford the alternatives.
KX450F - kickstand
posted December 25, 2006 08:41 AM
brock has a map for every configuration i could dream of(flies in/out, baffle in/out, street, track, maxton mile, you name it)
0.35958695411682 seconds processing time
