BIKELAND > FORUMS > ZX-14.com > Thread: Speedohealer settings... NEW TOPIC NEW POLL POST REPLY
DominicL
posted October 09, 2006 10:55 AM
It seems the speedo for the ZX14 is off... waaaaay off.
I'd like to get an accurate reading from mine, does anyone else out there use a Speedohealer?
And if so, what settings do you use? Nearest I can figure out , it's off by 8%.
Thanks guys.
TJ
posted October 09, 2006 11:44 AM
Thanks guys.
Use the search function http://www.bikeland.org/board/search.php
Lots of us have SpeedoHealers and this has been discussed at length. My stock speedo was off by 7% (verified by GPS). Your bike most likely has an error of 5% - 10% if gearing is stock.
Brock
Sponsor
posted October 09, 2006 11:57 AM
Set it at -90% and go 200 MPH...that's what we did!
Brock
  Ignore this member    Click here to visit Brock's homepage.
ninja14
posted October 09, 2006 12:25 PM
One word of caution.
While the SPEEDO is off a bit the ODO is quiet accurate stock. I have ridden 2 nonstop trips (stopped to gas, eat and piss....) over 1000 miles each and the ODO was damn near perfect. If you use a healer you will want to retain the original speedo error if you want the bike to count miles correctly. If you don't care then you can get a GPS and set the healer to be pretty close to real speed, but it will cost you with an incorrect ODO. This is more evidence of the fact that the ECU uses math to calculate the commands sent to the dash for the speedo, ODO and gear pos indicator <-------which will also suffer incorrect function if the % is great enough from stock.
......one small detail is that also as you turn the bike the numbers stray due to an effective reduction in wheel/tire size.....
DominicL
posted October 09, 2006 01:10 PM
Cool, thanks guys. Will use search function from now on, didn't realize it was on the main
forums page.
Looking forward to finding that RPM limiter in 6th.....
Bummer is, I have to go to Nevada to test top speeds, don't know of ANYWHERE in
California that I can safely get up there. Ah, the problems that come with big engines...
BobC
posted October 20, 2006 02:03 AM
On the European model with an MPH / KPH scaled speedo you can do a "convert kph to mph" on the Speedo Healer and the 300kph dial becaomes a 300mph dial, also no worries about hitting the limiter. It worked fine for me.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
fastestbusaaround
I eat Fish...
posted October 20, 2006 03:40 AM
You can do that on the N/A models as well...
FYYFF!!!
0.24840593338013 seconds processing time
