BIKELAND > FORUMS > ZX-14.com > Thread: ignition advancer for the 14? NEW TOPIC NEW POLL POST REPLY
mrsantafe
posted October 08, 2006 10:02 AM
Does anyone make one yet?
2006 ZX14 gone
2004 zx10r (her race bike)
2002 ZX12 (still kicking a--)
2007 gsxr 1k (race bike)
Bronze Star Racing
posted October 08, 2006 11:33 AM
Dynojet
zxbob
posted October 08, 2006 12:50 PM
More info please !
Bob
TJ
posted October 08, 2006 01:13 PM
PC3R allows for ignition timing adjustments.
zx1kr
posted October 08, 2006 01:26 PM
That is not correct. Ignition Module from Dynoje & must be used in conjunction w/ PC3usb
smiddy1
posted October 10, 2006 02:32 PM
This does both
http://secure.mycart.net/catalogs/catalog.asp?prodid=4781842&showprevnext=1
Get on the line and drop it!
The Nitrous Advice Forum
INTIMIDA2OR
RED rider!
posted October 10, 2006 03:23 PM
Cool!
'06 Passion Red ZX-14
*Lee*
posted October 10, 2006 04:53 PM
That will onlt allow 2 degrees advance.... marginal power gain (1%).
Its meant for nitrous and boost, which NEEDS timing retarded....
ninja14
posted October 10, 2006 11:43 PM        Edited By: ninja14 on 11 Oct 2006 00:43
16degrees..............2% of engine power...........
Get one here
ZXLNT
posted October 11, 2006 02:36 AM
16 degrees of Timing RETARD not advance..
ryan schnitz
posted October 11, 2006 04:20 AM
The EFIR-14 unit allows up to 6 degrees of advance and up to 16 degrees of retard. It will advance the timing when running on motor, then retard for nitrous or boost. (12 volt activated)
Ry--
ninja14
posted October 11, 2006 08:05 AM
Ah...I see. That makes perfect sense for the nitrous set-up.........
That's a little spendy for 6degrees if you are not using nitrous :-)
ryan schnitz
posted October 11, 2006 09:09 AM
Yeah, ignition advance was an added feature to the retard unit.
Designed for retard with nitrous/turbo. But, can be used only as an ignition advance if desired.
Ry--
mrsantafe
posted October 12, 2006 07:32 AM
Thanks for the answes fellas. Approximately,how much of a hp increase should i expect from the ignition advancer with just bolt ons?(pipe, pc, etc)
ninja14
posted October 13, 2006 12:37 AM
Depends on what "etc" is............
Slip-on and PC tuned can get you to about 175, but peak power numbers don't tell all.
I have no flies, dual CF slips, tuned PC, some home made wiring tricks and 16/43 gears. I can carry the front tire all the way through second gear and some of third (not talking about high up wheelies BS, but big power with me trying to hold it down with my 195lbs on the front of the seat)
The extra 6 degrees won't get you anywhere near that kind of flying........
posted October 15, 2006 08:20 AM
be carefull with the timimg if you don't use good gas you will get detonation
INTIMIDA2OR
RED rider!
posted October 15, 2006 06:45 PM
This one advances ,retards and controls fuel too:
BIKE COMPUTER
*Lee*
zx14_1965
posted October 15, 2006 07:49 PM
Already have one - got it for really really cheap...to be installed and PCIII custom mapping to be done on Tuesday.
ninja14
posted October 16, 2006 12:29 AM        Edited By: ninja14 on 16 Oct 2006 01:30
Try my free version.............
.......here
zxlnt
posted October 16, 2006 12:49 AM
Yep that's the same thing that was done with the ZX12R's before the igniton advancers were available.
zx14_1965
posted October 16, 2006 08:10 PM
.......here
Very intuitive....
ninja14
posted October 16, 2006 11:10 PM
Soon as I got my service manual and saw the set-up I knew it would be simple......and cheap :-)
Y2KZX12R
CompetitionCNC.com
posted October 17, 2006 07:06 AM
You need to set the rotor gap also.
You might want to add that into your instructions. Tell them to use a feeler gauge and measure the rotor gap and then set it when tightening the pickup coil bolts.
Y2KZX12R
CompetitionCNC.com
0.23219084739685 seconds processing time
