BIKELAND > FORUMS > ZX-14.com > Thread: Can't get my dyno jet shifter to work ...*^%*^&^& NEW TOPIC NEW POLL POST REPLY
posted October 05, 2006 03:29 PM        Edited By: smokinZX14 on 5 Oct 2006 16:30
I got it all mounted and set per the dyno jet paper work and it doesn't work ..I set it 100 times and still doesn't work . I even took it off the shift lever and worked it by hand ..I rev'ed the motor to ten grand and worked the switch by hand and it never kills the engine ..The red and green LEDs are working but it will not shift ...I'm really tried after 50 test rides!!!
HELP !!!!!!!!!!!!
Vegasdude
posted October 05, 2006 03:40 PM        Edited By: Vegasdude on 5 Oct 2006 16:41
what is your rpm and kill time set at. Try 65 milliseconds and 6000 rpm. You do have it plugged in to your PC3?
Bently
2012 14r In Blue and no Mods!
posted October 05, 2006 03:45 PM
Did you turn on the quickshifter feature with the cd that came with it
posted October 05, 2006 04:40 PM
Didn't know you had to turn anything on.... Paper work that came with it said nothing about turning anything on ...Just plug and play ... Fuck me now i have to take my bike all apart and bring the P/C to my home and go get a friggin 9v battery ...... Thanks Bently for the info...I should have known better that nothing is plug and play ..
posted October 05, 2006 04:46 PM
No i plugged into my toaster...Sorry i couldn't help myself .. I was told it was pre set by the factory at 4000 and 65ms so i plugged it in thinking that all i need to do ......Nobody told me i had to hook it to my computer and turn the damn thing on ..You would think they would put that little tid bit in the paper work...
Bronze Star Racing
posted October 05, 2006 05:50 PM        Edited By: Bronze Star Racing on 5 Oct 2006 18:53
Let me know how that thing works... I knew a guy who had it on a ZX-10 and it wouldn't shift under a good load at the strip
kspz3
posted October 05, 2006 06:09 PM
I am using the quick shift with the button - it works great shifting at 10,500 -(actual - 11,000 indicated on tach).
kspz3
posted October 05, 2006 06:10 PM
Also I have the delay set at 85 - also you do not need to have the battery - just start the bike up - the quick shift settings are in the tools menu.
KSP
posted October 05, 2006 06:18 PM        Edited By: smokinZX14 on 5 Oct 2006 19:20
KSP
Well the bike is hard to get up the second story to hook to my Puter, so i think i may need that battery ... Unless you can loan me a 150 foot cable ...
Bently
posted October 05, 2006 06:20 PM
Hope you got it working, to bad I'm so far away you could have used my laptop (LOL)
posted October 05, 2006 06:23 PM
What your only 2000 miles away ... come on down and i'll buy dinner ....
vegasdude
posted October 05, 2006 06:26 PM
nothing is plug and pray...........hopefully you can get it to work........
salsa1
posted October 06, 2006 12:02 PM
Can a laptop be rented? just a thought..I borrowed a laptop from work for my ZX-10R dynojet initial going..
I called up a dynojet rep. on the phone from my garage and he basically walked me thru a few basic steps to get it going.. I am using 65ms.. works good for me..
Salsa1
posted October 07, 2006 01:04 PM
Ok it's up and running ..... Going to test it tonight on the street and then on Wensday at the track... Keeping my fingers crossed ...
iflyphi
posted October 07, 2006 04:49 PM
Anybody using the PIngel electric shifter?
Bently
posted October 07, 2006 06:56 PM
Good luck smoking, I think you will be happy with it.
vegasdude
posted October 07, 2006 11:35 PM
I knew the toaster idea was wrong..........
posted October 08, 2006 07:17 AM        Edited By: smokinZX14 on 8 Oct 2006 08:18
Well guys at first i wasn't really happy with the shifter, I missed more gears than i hit.... Later that night we stop and reset the switch so the kill came on faster and that seems to have done the trick ... I made two full out passes and hit all the gears with no problems ...It's a very smooth shift , not jurky and no wheelies on the 1 to 2 shift like it would do foot shifting......It's seems to shift smoother and quicker than my MRE air shifter that was on my other bike...
Next test will be at the 1/8 track next Wensday night ...More to come ...... Smokin...
Bently
posted October 08, 2006 07:42 AM
Smokin, what did you set your kill at?
posted October 08, 2006 07:47 AM
65 ms .. Seems to work ok at that setting ...
Bently
posted October 08, 2006 07:53 AM
Thats where mines at as well.
posted October 08, 2006 07:55 AM
Bently what kind of ET and MPH gain did you get out of the Quick shifter Vs foot shifting ?
Bently
posted October 08, 2006 06:03 PM
Smokin wish I could tell ya, but I put my Smeg, pc and quickshifter on at the same time. so I don't know how much it helped.
posted October 08, 2006 06:06 PM
Ok cool ...Just thought i'd ask ..Guess i'll find out wensday night .. Smokin...
BIKELAND > FORUMS > ZX-14.com > Thread: Can\'t get my dyno jet shifter to work ...*^%*^&^& NEW TOPIC NEW POLL POST REPLY
0.28215503692627 seconds processing time
