BIKELAND > FORUMS > ZX-14.com > Thread: FI light NEW TOPIC NEW POLL POST REPLY
NINJA12
posted October 01, 2006 04:56 PM
FI light
Anyone had the FI light , with FI error nessage?
Light come on bet the bike even starts.
Suggestion?
vegasdude
posted October 01, 2006 05:16 PM
take off battery leads for 5 minutes. Reconnect.........
ninja12
posted October 01, 2006 05:21 PM
tried it.
posted October 01, 2006 06:52 PM
whats your code, I'll tell you what it means.
NINJA12
posted October 01, 2006 07:04 PM
how do you pull codes from this bike?
ZXLNT
posted October 01, 2006 08:23 PM
Not a very helpfull post here, but I can't belive you have this sophisticated of a machine and dont have the service manual... Its a must have, especially in your kind of situation..
posted October 01, 2006 08:49 PM
should flash a code at you.
"error code_ _"
posted October 01, 2006 09:44 PM
I'd advise taking it to a dealer, since you don't understand how to read trouble codes off of what's pretty typical since oh, 2000 or so...
posted October 01, 2006 09:47 PM
If he has bad ecu ground or power connection it will not read a code number, just "efi error"
1st thing mentioned in the manual in efi trouble shooting section
sphynx
posted October 01, 2006 10:34 PM
I know the manual say's this but remember that if you have more than one key on the key ring (or close proximity to each other) when you turn the ignition on, it will also give the same error.
"My ambition in life I's to become the person my dog thinks I am" by rabbits losing lucky feet.
ninja14
posted October 01, 2006 11:00 PM        Edited By: ninja14 on 2 Oct 2006 00:01
Hold down the mode button a few seconds and it will show a code.....same a clearing the flashing fuel warning.
speedgene
posted October 01, 2006 11:37 PM
Simultaneously, press "reset" and "mode" together. That is how you retrieve codes. What are the code(s) numbers?
E-tard
ninja14
posted October 02, 2006 12:14 AM
Yeah......both........
I went through the 62 and 32 while messing around to see if I wanted to remove the secondary rod - decided not to.
butterthegreat
posted October 02, 2006 06:23 AM
Or so....try like 1990
posted October 02, 2006 06:26 AM
Not for bikes.
butterthegreat
posted October 02, 2006 06:37 AM
Not for bikes.
Ah....I stand corrected. LOL. I thought you were speaking "in general".
ninja12
posted October 02, 2006 09:38 AM
error code 24.
speedgene
posted October 02, 2006 12:53 PM
Service Code 24 - Speed Sensor: Speed sensor needs to send 4 output signals to the ECU via one c/shaft revolution.
Recheck your wiring if you pulled the cover, or wired in a unit which is looped with the drive sprocket area? Pinch, poor ground, disconnected?
E-tard
fastestbusaaround
I eat Fish...
posted October 02, 2006 01:07 PM
Did you install a Speedohealer?
FYYFF!!!
ninja12
posted October 02, 2006 01:33 PM
no speedhealer.
FI Light flashes on as soon as the key is turned.
Gear position indicator flashes as well.
Bike throws code before it starts.
ninja14
posted October 02, 2006 03:45 PM
That's a Hall sensor........they go out sometimes............
If you know sombody with another bike you can trade to see if it does the trick...or go buy one.
Have you changed the front sprocket? - Pull the cover to make sure the nut is still there :-)
SanteeZX14
posted October 02, 2006 05:13 PM
Or take it to the dealer and have it changed under warrenty....
2006 ZX14 (Faster RED Version)
2004 EX250 (Baby Ninja)
2003 ZRX (Green of course)
Philhnnss
posted October 02, 2006 08:01 PM        Edited By: Philhnnss on 2 Oct 2006 21:02
Try 1984 as in the ZX750E or better known as the 750 Turbo.
ninja12
posted October 02, 2006 08:13 PM
Ok, guys this is a custom show bike with probably 15-20K worth of work.
IF you don't want your stock bike going back to the dealers, don't suggest it to others.
Really doubt they would do w.arranty work, as most dealers around here find
some reason not to. Even if he took it in the wheel or pipe would void the warranty.
I really appreciate the one who are tring to help.
Can you Automotive history teacher find another thread.
posted October 02, 2006 08:33 PM
I agree,
trolling and flaming doesn't belong with assistance, and repair threads....
No one would appreciate it ,If it was anyone of us and our thread was hijacked.
0.26582288742065 seconds processing time
