BIKELAND > FORUMS > ZX-14.com > Thread: Quick derestrict NEW TOPIC NEW POLL POST REPLY
SuperRetard
On the blag
posted September 19, 2006 04:23 AM
Quick derestrict
Hi folks, have used search, but to no avail.
I have the opportunity to run my ZZR1400 tomorrow on a 2.2mile strip with timing equipment, and want to crack 200mph.
I've been told I can disconnect the speedo cable to bypass the limiter (which kicks in on mine at around 183mph), is this true?
Cheers,
Dale
ZZR14, PC3, butterflies, TiForce
Project Cannonball!
BobC
posted September 19, 2006 04:35 AM
Just disconnect the three pin connector which carries the gearbox sprocket tacho pulse up to the ECU. Follow the cable which emerges from the centre of the sprocket cover (down on the left-hand side of the engine) after a few inches of cable you will find the connector.
Do this on the start line. You'll get one run before the ECU goes into error mode. Switch off the ignition and re-connect to re-set the ECU. Do the same sequence on your subsequent runs. A bit of a pain but it works.
Removing the mirrors and lowering the bike helps quite a lot ! Good luck.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
SuperRetard
On the blag
posted September 19, 2006 04:37 AM
Cheers mate! Am still on stock gearing but with a 190/55 rear, so it'll be interesting to see what I can get.
Project Cannonball!
BobC
posted September 19, 2006 04:53 AM
Should pull around 190 at peak power on stock 17/41 gearing. If you can hit the limiter in 6th you'll be doing 204.
A totally stock 14 ran a 198.7mph at Woodbridge earlier this month, that was with mirrors on, standard exhaust etc. Just with a Speedo Healer to de-restrict.
Stock wheelbase
SuperRetard
On the blag
posted September 19, 2006 05:08 AM        Edited By: SuperRetard on 19 Sep 2006 06:10
http://img82.imageshack.us/img82/6701/powernv9.jpg
Well, I'm up by 20bhp at the limiter, so hopefully 200mph is on the cards.
Fingers crossed for the wind...
Project Cannonball!
BobC
posted September 19, 2006 05:20 AM        Edited By: BobC on 19 Sep 2006 06:32
Given the right weather conditions you could do it.
My 14 is geared 18/41 and pulled around 10250rpm to go through the timing equipment at 205.4mph. That's with Tiforce system, PC, Speedo Healer and lowered. 192.9 rear wheel bhp.
Just a thought, if you're looking for a UK ZZR1400 top speed record then Rob, ex-employee of Colchester Kawasaki, ran a 207mph dead at Woodbridge during JD9. I haven't heard of any faster !
Stock wheelbase
0.28333806991577 seconds processing time
