BIKELAND > FORUMS > ZX-14.com > Thread: Can't install system. Hit filter! NEW TOPIC NEW POLL POST REPLY
NAVIGATOR
posted September 16, 2006 07:22 AM
I have a SuperTech ST7317 oil filter on my bike. The head pipes won't clear. Do I have to use the Kawa filter? Is there something else that I won't have to drive 20 miles to get. Need answer quick. I'm in the middle of this install.
NAVIGATOR
posted September 16, 2006 07:25 AM
Sorry. I'm in a hurry here to get this done and forgot say that I am installing the Brock Gen III.
flatoutbu
posted September 16, 2006 07:36 AM
I have the same problem but there are a few things you can do to help that. One leave the exhaust loose and before you tighten it up, pull it away from the filter and tighten it up...if you still have a problem...and yes this sucks.....dimple your oil filter. I took a small rubber hammer and dempled the corner of my oil filter to clear the pipes. If you ever have a chance, use the 002 oil filter it's alittle shorter and it clears alot better. I have not tried this but you might be able to wrap a ratch it strap around the pipes and tighten it down, then tighten your header bolts up...that might get you the clearance you need.
06 Blue 14
9.008 at 153mph @ 195 suited
NAVIGATOR
posted September 16, 2006 07:40 AM
I just did some cross referencing and found out that the 7317 is 3.25 inches long and I can get the same filter under another number that is 2.75 inches long. Going shopping. I'll let you know how it turns out.
blitzkrieg
Road kill = Free lunch.
posted September 16, 2006 08:17 AM
Use the Purolator Pure1 PL14612.
It's one of the best filters on the market and should clear your header no problem (it's 2 3/4" long).
Advance Auto carries them. They are about $5 a pop.
I run that filter on both my 12 and R1.
GUNNER
posted September 16, 2006 08:20 AM
AGREED!!!!!!!!!!!!!!!! Use the PureOne it's the best filter out there
posted September 16, 2006 08:28 AM
+1
posted September 16, 2006 08:33 AM
Oh yah?? Well +2!!
blitzkrieg
posted September 16, 2006 08:43 AM
+3.
(Can I do that?)
GUNNER
posted September 16, 2006 08:59 AM
Well if you can I should be able to say +4
posted September 16, 2006 11:01 AM
I'll take the bait
+4
NAVIGATOR
posted September 16, 2006 12:17 PM
Local parts house didn't have the Purolator but did have the Mobile 1... M1-108. It is a direct cross and gives plenty of clearance.
I finished installing the system, the PC and removed the flys. Couldn't get the nut off to change the front sprocket. Will have to do that at work next week with the impact tools.
I just got back from my test flight. FUCK ME !!!!!!!!!!!!! Why didn't I do this sooner? It is unreal and sounds perfect. Power from the bottom to the top.
The black system with the carbon fiber canister looks badass. I'll post pics later.
Brock
Sponsor
posted September 16, 2006 01:59 PM
Our system is appropriately oversized to allow the 14 TO BREATH.....especially when the ram air starts pushing even more gasses through an already thirsty engine. The fit is VERY tight...but it is what you need to go as fast as possible.
We can only make systems to function to work with O.E.M. parts because aftermarket items are not readily available to everyone.
Thanks to all for helping Navigator!
Brock
Ps. He has a prototype system that I think all will enjoy!
  Ignore this member    Click here to visit Brock's homepage.
blitzkrieg
posted September 16, 2006 02:29 PM
No worries on the Mobil1. It's a top flight filter too.
Generally speaking in independent testing the ranking is:
#1 Purolater Pure1
#2 Mobil1 (very close second to tie depending on who's doing the testing)
#3 Bosch
cls
posted September 16, 2006 03:40 PM
Brock,
But should I be concerned your system header is hitting the oil filter. I mean, like, pushed into it. That doesn't seem cool (Pun intended.). Something I should do/check?
lietoome
posted September 16, 2006 03:43 PM
My oil filter is rubbing my carbon muffler...WTF?
Nevermind, just needed more of the copper stuff.
NAVIGATOR
posted September 16, 2006 06:24 PM        Edited By: NAVIGATOR on 16 Sep 2006 19:25
Brock
Breathing? Is that what you call it Brock? Call it what you like. My bike runs like a bat out of hell. This is how a 14 is supposed to feel and sound. The great thing is that I didn't lose any of the smoothness that this bike is known for and now I won't have to watch out for that 6k rpm hit coming out of 2nd gear corners. It just pulls hard as soon as I twist the throttle.
Brock, I can't say thank you enough for helping me make my bike look, feel and sound just the way I wanted.
And to all the helpful members of this forum, for the filter assistance, for good advice and for being resourceful, inventive, and willing to test new ideas on your bikes THANK YOU, THANK YOU, THANK YOU.
cls
posted September 16, 2006 06:43 PM
So, you like it?
posted September 16, 2006 06:44 PM
I dunno...He sounds kinda wishy washy.
Buz
zx pilot
posted September 17, 2006 08:15 PM
Brock
No pictures???
BIKELAND > FORUMS > ZX-14.com > Thread: Can\'t install system. Hit filter! NEW TOPIC NEW POLL POST REPLY
0.46762800216675 seconds processing time
