BIKELAND > FORUMS > ZX-14.com > Thread: What are your speeds @ redline in 1st, 2nd gear ?? NEW TOPIC NEW POLL POST REPLY
jetman2
posted September 16, 2006 06:15 AM
I'm curious what your speeds are at redline in each gear. What rpm/speed are you shifting at for MAX acceleration in the 1/4 mile. How much difference does the 16 tooth front spocket make ? Has anyone actually looked at the speedo at redline ?
Black 2006 ZX-14
posted September 16, 2006 06:27 AM
In Order
1 . don't have time to look...
2. 11,000
3. none at all..
4. don't have time to look...
shawnski
posted September 16, 2006 07:00 AM
all i can tell you is first and second gear, afraid to look down after that
1st gear: 85 miles
2nd gear 115 miles
this is all stock gear and sprocket etc..,except pc3 and muzzy pipe.
ninja14
posted September 16, 2006 07:01 AM        Edited By: ninja14 on 16 Sep 2006 08:02
If you are trying to race then what matters if shifting at the right time per gear......no matter what gearing you have. You get a dyno run (or look at some charts on here) and you figure out when to shift per gear that allows the motor to drop back down to about peak power after a shift. The 14 flows good air to redline and it may be best to simply set the shift light to 11K and go for it..................or simply load the lever and let the limiter do the work :-) <-------careful on the 1-2 shift though.....this method will cause you to loop it :-)
BROOKLYNNYZX12
posted September 16, 2006 07:21 AM
Stock '03 ZX-12 stock gearing,drag racing 140 mph going through the traps at Englishtown!3rd gear
Tool man
posted September 16, 2006 08:17 AM
Look where your going, when going fast at redline Sheeesh :P
The banks are failing..
The banks are failing...
Invest in Ammo
bugsey
posted September 16, 2006 11:03 AM
I'm on my cell phone at redline....look at the paper, too
posted September 16, 2006 07:10 PM
I think about 140 , and 190 kmhr, all I know is when hammered into first on the highway, at 90- 100km to pass cars is the front is about 2 feet off the ground and pullin like a sum a bitch! LOL
lietoome
posted September 16, 2006 07:16 PM
...really fast.
weaver
posted September 16, 2006 10:16 PM
Speed in gears in km/h is as follows - multply by .621 to convert to mph
1st 128
2nd 172
3rd 217
4th 252
5th 291
6th (if unrestricted) 324
Obtained from www.kwon.nl/ZX-14R_TopSped_and_Gears.jpg
jetman2
posted September 17, 2006 05:50 AM
Thanks for the info !!!
Black 2006 ZX-14
ZX11D
Internet Police
posted September 17, 2006 06:27 AM        Edited By: ZX11D on 17 Sep 2006 07:28
1st 128
2nd 172
3rd 217
4th 252
5th 291
BobC
posted September 17, 2006 07:39 AM
1st gear: 85 miles
2nd gear 115 miles
That's your bike's optimistic speedo I assume ?
Mine is running 18/41 gearing and accurately calculating speed at 10800rpm gives:
1st = 85mph
2nd = 115mph
3rd = 145mph
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
SoCal ZX-14 Rider
posted September 17, 2006 10:51 AM
Just pushing Fish's posts down the board. lol
If I'm not riding her, I'm dreaming about riding her! Mount up!
posted September 17, 2006 07:20 PM        Edited By: dubious on 17 Sep 2006 20:20
my optimistic tach reads 11300 - 11500 before the rev limiter
kspz3
posted September 17, 2006 09:16 PM        Edited By: kspz3 on 17 Sep 2006 22:16
80
108
136
158
183
210 - resstricted to 187
sands
posted September 17, 2006 11:27 PM
Doesn't the 10 and R1 exceed 100 mph in 1rst ?
I figured with the torque the 14 would run a taller 1rst gear.
www.nonationalid.com
BobC
posted September 18, 2006 02:10 AM
The 14 isn't a sports bike with a track-focus, it does not have a close ratio box. It's a hyper-bike masquerading as a sports-tourer. Doesn't need 100 in first for bragging rights, it blows the others into the weeds anyway when the power is unleashed.
Stock wheelbase
halvefast
posted September 18, 2006 05:03 AM
I'm geared down -1 on the front, 16T, shift @ 10500 on my tach weighing 775 bike & rider
and ask anyone at the track it lofts the wheel in both 2nd and 3rd gears.
Put on a really good show Fri. night in the finals. Ran the points leader on his 00 ZX12,
even he said he was impressed with the 14's power, never seen a big bike do that,
2ft. wheelie in 3rd! Got my attention I'm tellin ya.
ECTA Ohio Mile 195.132mph
posted September 18, 2006 05:22 AM
Those big wheelies will do that! Ever launched, hooked, moved off the line and then break loose and go up in smoke? That's fun too!
0.49332904815674 seconds processing time
