BIKELAND > FORUMS > ZX-14.com > Thread: Strapping the front for the first time, need advice NEW TOPIC NEW POLL POST REPLY
lietoome
posted September 08, 2006 02:44 PM
Never used a lowering strap before, is there anything I need to be particularly careful of? I am using the Schnitz strap (radial mounted). Thanks for the info.
posted September 08, 2006 03:32 PM
No much to do ... Put the pull strap on the left side so you can hold the front brake with your right hand ... Put a zip tie around the buckel and tie it to the brake line so it doesn't swing into the rad when not pull tight ...
posted September 08, 2006 03:39 PM
Keep the twists out of it, straight from one side to the other.
Make sure your not pinching or interferring with any brake lines,
Some guys use 2 straps, one for each side...
lietoome
I never would've thought of the zip tie, thanks smokin'. If It dries up some more, I may get some runs in tonight.
posted September 08, 2006 03:45 PM
There are 2 screws in the frame on the right side, near the steering head, they don't hold anything, just screwwed in to the frame, I made a braket for each, when cinched down the tie holds the slack and I use the bottom screw, when loose for street riding i used the top braket.
flatoutbu
posted September 09, 2006 05:54 AM
I used one of those belt /mountain climbing hook thingys you can get at wallymart to loop thru the pull handle, then I made a tab that bolts on the bike, I just clip it too it when its strapped. if you start having traction problems with the front end strapped down loosen the strap up alittle it will help.
06 Blue 14
9.008 at 153mph @ 195 suited
posted September 09, 2006 06:24 PM
Oh yeah, don't strap it all the way down, bad for wobbles with no travel left and alot of stress on the frame if you wheelie and come down with no suspension left.
Our association mandates 1.5 inches clearance under the bike and minimum 1.25 inches travel left.
0.2385139465332 seconds processing time
