BIKELAND > FORUMS > ZX-14.com > Thread: Check your Nuts NEW TOPIC NEW POLL POST REPLY
lietoome
posted September 06, 2006 08:34 PM
Check your Nuts
While installing the exhaust last night, there were a LOT of screws that were barely hand tight. Next time you have your plastics off, check your header nuts. 3 of mine were hand tight--at best. I've already lost 3 screws that have vibrated out. I know some of the more seasoned guys already know to do this, but I knew to do it too after my '03 12 lost several screws within the first 1000 miles. I told myself I'd check a them, but never bothered. I regret it now.
INTIMIDA2OR
RED rider!
posted September 06, 2006 08:56 PM
Yep i found this out when changing my buddy's exhaust out but only 2 were kinda loose .
Lots of fairing bolts were hand tight and so was the lower radiator support too!
Strange!
'06 Passion Red ZX-14
*Lee*
lietoome
posted September 06, 2006 09:01 PM
I need to check that radiator support. I'll check everything one more time before i put my plastics back together.
fastestbusaaround
I eat Fish...
posted September 07, 2006 02:30 AM
My nuts are good, but my dick's all bruised from smashing into the tank under hard braking. :P
FYYFF!!!
ghost ryder
posted September 07, 2006 09:45 AM
I can't seem to tighten the one behind the steering wheel............LOL
  Ignore this member    Click here to send Ghost ryder an AIM message.
fastestbusaaround
I eat Fish...
posted September 07, 2006 09:54 AM
Like I always say..."The problem lies between the chair and the keyboard"
FYYFF!!!
SoCal ZX-14 Rider
posted September 07, 2006 11:12 AM
Ya - all the plastic screws come loose.
Haven't run into a loose screw or nut beyond the ones that hold the plastics.
If I'm not riding her, I'm dreaming about riding her! Mount up!
INTIMIDA2OR
RED rider!
posted September 07, 2006 11:22 AM
You're not looking hard enough LOL!!!
*Lee*
chez
posted September 07, 2006 04:15 PM
A word of WARNING!!! Don't put Loctite or similar anywhere near plastic, eat it's the stuff!!!!!!
Chez
  Ignore this member    Click here to send Chez an AIM message.
countersteer
Didn't read the owners manual
posted September 07, 2006 06:18 PM
oh yeah? what about semen?
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
fastestbusaaround
I eat Fish...
posted September 07, 2006 06:43 PM
Loctite eats through semen as well
FYYFF!!!
INTIMIDA2OR
RED rider!
posted September 07, 2006 10:18 PM
*Lee*
QScott56
posted September 08, 2006 04:59 AM
I found my nuts loose also after changing to Muzzy!
A great thing to use is Lock Tite. You can get it from any Auto Part Store. They have Blue and Red................DO NOT use the red........cause if you ever have to remove those nuts....wont happen happen unless you cut it off with a welder. So the Blue is the way to go....................it comes in a little tube and looks like a blue glue stick. Put a little on the bolt, prior to putting the nut on. No more nuts vibrating loose!!!!
lietoome
posted September 08, 2006 05:14 AM
If you MUST use the loc-tite, just use it on the bolts that do not have the rubber/brass grommet. The Grommeted screws do not seem to be effected by the vibrations of the bike.(i.e. the bottom rear fairing bolts behind the pegs will not come loose). The lower fairing bolts are the ones that my need a dab of the loctite.
fastestbusaaround
I eat Fish...
posted September 08, 2006 08:40 PM
Red can be easily removed...don't know why you say it can't...
FYYFF!!!
sands
posted September 09, 2006 12:49 AM
Hey guys....What is it with Kawasaki motorcycles having problems with bolts that always come loose ? It seems like this is the most common issue with Kawasaki's.
It seems like the ZX10 is having issues with this as well...There was a thread about this on another zx site and there were alot of 10 owners complaining of the same thing...
www.nonationalid.com
Ozzy
need guberment cheese
posted September 10, 2006 03:53 PM
Basically you are correct, but Loctite does make a locking compound that is ok to use on plastic.
posted September 10, 2006 04:01 PM
I found a lot of stuff loose when doing my exhaust. Even the two bolts that are in front of the tank were screwed almost all the way out.
0.25937008857727 seconds processing time
