BIKELAND > FORUMS > ZX-14.com > Thread: 139 sixty foot times NEW TOPIC NEW POLL POST REPLY
RICH CRAFT 1
posted September 04, 2006 08:40 AM        Edited By: RICH CRAFT 1 on 4 Sep 2006 10:26
Well we had a little better weather from our normal 106 degree days, went out Friday
night, started raining, then dried off, temp 84, humidity 61%, correction factor 1.0715,
60 ft 1.396, 330 ft 3.762 @ 95.46, 1/8 mile 5.742 @ 122.00, had a ten mile hr
head wind as usually we have a ten mile hr tail wind. STD run 60 ft 1.364 doubt that, 1/8 mile 5.608 126.56, 1/4 mile 8.831@154.34, STD HP 198 waiting for cooler weather. Mods Brocks Genisis 3,rider and bike 690lbs
pc/roaring toys swing arm extensions 7 over, air shifter mps, pump gas 93.
Red 06 ZX14 RR
tonytooth
posted September 04, 2006 08:58 AM
Very nice!
MySpace
  Ignore this member    Click here to visit tonytooth's homepage.
Bently
2012 14r In Blue and no Mods!
posted September 04, 2006 10:36 AM
Good job Rich Craft
lucky14
posted September 04, 2006 10:38 AM
AWESOME!!!
posted September 04, 2006 03:24 PM
Ok Let see if i read this right ....... you ran 1/8 mile track and ran a 5.74@122 ... The 1/4 mile numbers you posted is a Est or guess? Good job on the 5.74 pass ...Let us know when you do run the 1/4 mile ... Smokin..
flatoutbu
posted September 05, 2006 08:44 AM
Yea i seen that too.... so the bikes set up for 1/8 mile, thats why we see 1.39 sixtys? If I remember your geared to death to run 1/8th right? I would think you would run out of gear before the 1/4. I have a 16/42 and the speedo see's 180 going thru the traps....going with a 43 tonight and i'm thinking it might shut off right at the traps. I'm also going another inch out so i'll be at 7 total.
06 Blue 14
9.008 at 153mph @ 195 suited
RICH CRAFT 1
posted September 05, 2006 10:40 AM
16-48=166mph 16-42=190mph
Red 06 ZX14 RR
flatoutbu
posted September 05, 2006 12:34 PM
My bike does not have the speed calibrator, it shows 180 when i go thru the traps. Where are you finding 48 tooth sprokets? Everybody I talked too only has 43 as the biggest?
06 Blue 14
flatoutbu
posted September 05, 2006 12:35 PM
my MPH is usually 150-151 thru the traps
06 Blue 14
RICH CRAFT 1
posted September 05, 2006 02:49 PM
www.vortexracing.com part#427-48-p ph727.3761130 amount 63.95
Red 06 ZX14 RR
Nukedog
posted September 07, 2006 05:28 AM        Edited By: Nukedog on 7 Sep 2006 06:29
How do you keep the front down? 16/48? Holy shizzit!
PS - where were you at? That is some low humidity...
02 Busa...Turbo...
09 YZF-R6S...
RICH CRAFT 1
posted September 07, 2006 06:41 AM
extensions 7 over. dallas texas.
Red 06 ZX14 RR
flatoutbu
posted September 07, 2006 09:55 AM
even 7 over i had to put my fat belly on the tank to keep it down...
06 Blue 14
RICH CRAFT 1
posted September 09, 2006 09:12 AM        Edited By: RICH CRAFT 1 on 9 Sep 2006 10:18
QUOTE: Ok Let see if i read this right ....... you ran 1/8 mile track and ran a 5.74@122 ... The 1/4 mile numbers you posted is a Est or guess? Good job on the 5.74 pass ...Let us know when you do run the 1/4 mile ... Smokin..
_____________________________________________________________________
This was not a guess I use a race air pro computer which most of the pro stock guys use
to estimate part or whole runs. The hardest part of a 1/4 mile run is to get the numbers
by the 1/8 mile and really everything is finished by the 330 from there you are basically hanging on. The STD run that I posted 8.83 was based on perfect conditions which we do see here in the winter. My actual run that night 5.74 would have been 9.03 @ 150.89.
I live 15 miles from the Texas Motorplex 1/4 mile but we don't have a NHRA license and cannot race there but we are working on the license thing.
Flatoutbu did you find the sprocket that I posted?
Red 06 ZX14 RR
psycho1122
posted September 09, 2006 10:44 AM
690 lb. rider and 14 w/ a 150+ trap speed indicates 180-185 h.p.
RICH CRAFT 1
posted September 09, 2006 11:03 AM        Edited By: RICH CRAFT 1 on 9 Sep 2006 12:04
yes185@1.0715 STD@1.0000=198HP (quote) Well we had a little better weather from our normal 106 degree days, went out Friday
Red 06 ZX14 RR
posted September 09, 2006 03:27 PM
Thanks Rich ..I Raced Ennis before... I lived in Corsicana TX , just 19 miles south of Ennis...Also raced Green Valley and Seven Points ( Ceader Creek)... Smokin....
flatoutbu
posted September 11, 2006 04:34 AM
I didnt find it on the website but I will call about it. I was also told bye a guy from Marvick that the 04-05 zx10 back wheel are the same pattern as the 14 and the front wheel is the same as the 12. They go strictly off of measurements so i'm not sure if the cush is the same but i know the sizes are the same.
06 Blue 14
lucky14
posted September 11, 2006 10:36 AM
Ahhhhhhhhh........Green Valley!
Waiting in line on the 2-lane road for the gates to open.
Fighting the hard South wind all Spring and Summer and waiting for that first Norther.
Thinking that my low 9's were fast...........................and now 14's are nearly there stock.
RAC4IT
Bergie
posted September 11, 2006 10:54 AM
I guess at 7 over that's good, but damn, it's 7 OVER. What can you do on a streetbike
0.23806881904602 seconds processing time
