BIKELAND > FORUMS > ZX-14.com > Thread: Tilt down sensor rattle rattle rattle rattle NEW TOPIC NEW POLL POST REPLY
posted September 04, 2006 08:26 AM
alright.... so I check the tilt down sensor... tighten it, but the sensor itself sounds like a mexican rattle or some cheap castanets.... what gives?
dbeadling
posted September 04, 2006 08:54 AM
that looks like the secondarys butterflies..... better stuff that thing back in the air intakes...you might make the bike to fast and offend kawasaki by beating all busa around
lucky14
posted September 04, 2006 10:45 AM
Mine was the same way.
The only way to stop the rattle is to drill it, then fill it completely with lead shot and lime jello.
Wrap it with 0.37 mm of green duct tape and..............you're done!
I still don't understand why Kawasaki didn't do this from the factory.
posted September 04, 2006 12:32 PM
I solved the rattle by using earplugs.
fastestbusaaround
I eat Fish...
posted September 04, 2006 12:54 PM
I solved all the rattles with an iPOD
FYYFF!!!
BobC
posted September 05, 2006 12:01 AM
I put a cable tie round the damn thing.................sorted.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
chris3232
posted September 05, 2006 02:19 AM
Yeah, I used a zip tie around mine too. I don't notice it any more.
posted September 05, 2006 04:04 AM
extra washers on the bolts..........
vtxtc
posted September 05, 2006 04:57 AM
Rattle is caused from inside pendulum which tightening outside nuts will not fix-to verify hold tilt switch with two fingers and flick it with the other hand and you will still here rattle- I used multiple small pieces of dynamat to wrap sensor rattle is muffled about 95 %.
Dynamat can be bought at most car stereo stores.
TeamSpeed
posted September 05, 2006 05:13 AM
Wrapped weather stripping foam around the sensor. Puts pressure against the gauges to stop any movement, and quiets it down pretty substantially.
posted September 05, 2006 05:16 AM
I guess it's from years of working around 4500 psi air systems, 3000 psi hydraulic systems and 10K cfm cooling systems, cuz I don't hear no rattle.
0.26801109313965 seconds processing time
