BIKELAND > FORUMS > ZX-14.com > Thread: violent gear selection NEW TOPIC NEW POLL POST REPLY
sphynx
posted September 02, 2006 06:46 AM
Hi guys, just curious. Have heard and read that the zx14 gear selection is "snick snick" slick, however on my 14 it's only 4,5, and 6 that's slick. From 3rd to 1st it becomes increasingly violent. When I see a stop sign I start sweating now! I'm using the recommended oil (15w50 motul) and wanted to get your thoghts/experiences? Thanks in advance
"My ambition in life I's to become the person my dog thinks I am" by rabbits losing lucky feet.
posted September 02, 2006 06:51 AM
My Katana 750 had a little click in the first few gears. The ZX9 had a somewhat bigger click, and yes, the 14 has an even bigger click with an authority sound. On my bike it appears most obvious when shifting down into first, especially if i'm going faster than I should've.
I haven't given it much thought, and it hasn't been a problem in my 2700 miles.
posted September 02, 2006 07:08 AM
My zx14 trans is the best shifting trans i have ever owned....Smooth as Butter shifts....
sphynx
posted September 02, 2006 07:11 AM
SmokenZX14, So it's smooth going from 2nd to first? What oil you running, how many miles?
posted September 02, 2006 07:17 AM
15w50 is recommended??
Coulda swore 10w40 was recommended.
Yep, there it is on page 9 of the owner's manual.
10W40
vegasdude
posted September 02, 2006 07:44 AM
MIne is smooth both up and down............
sphynx
posted September 02, 2006 08:53 AM
Thanks swft, went by the table on the following page. Were I am the temp ranges from 10 to 40 degrees centigrade, as per books recomendation
posted September 02, 2006 09:37 AM
how many miles on yer 14?
sphynx
posted September 02, 2006 09:48 AM
950. It doesn't feel like anything mechanical is wrong, my chain tension is good too. However it just feels a bit violent when I shift from N to 1st. When the guys say there's smooth, does that mean 5 to 6 feels the same as N to 1st?
posted September 02, 2006 09:49 AM
950 miles or kms? either way give it til 2 k to be broken in.
sphynx
posted September 02, 2006 09:55 AM
sorry, miles. Does your snick into gear with a click, or a solid clunk?
posted September 02, 2006 09:58 AM
all bikes need to break in... you might want to ride it around for a day or two shifting through the gears repeatedly to allow it to continue to break in. At 950 miles you dont have enough time on the engine and tranny for it to be fully seated in. My 10R took until 2K miles before the shifting was perfect.
sphynx
posted September 02, 2006 10:05 AM
Noted, and will try. Thanks for the feedback.
posted September 02, 2006 10:16 AM
BTW - my bike engages 1st with a hefty clunk. Every kawi I've owned did that. Even my ZZR1200.
nabrxx
posted September 02, 2006 10:45 AM
My bike goes from nuetral to first with an audible "clunk" that you can feel through the bike. My 98 balckbird did the same thing throught its 80,000 mile life. I got used to it and it became a "heads up" notice for passengers to hold on at lights.
What we don't understand, we can
make mean anything... src="http://www.bikeland.org/board/i
mages/smilies/smile.gif" border=0>
sphynx
posted September 02, 2006 10:59 AM
That's exactly what mine does, so this is normal then. Why would vegasdude and smokinzx14 gearboxes not do so? Thanks for input, thought I may have had a gremlin!
Stalwart
posted September 02, 2006 11:05 AM
If I pump the clutch twice and hold, the "clunk" into first from neutral is greatly reduced.
Stuart
Ridin' the Trump train.
posted September 02, 2006 02:18 PM
I haven't tried that...
fastestbusaaround
I eat Fish...
posted September 02, 2006 03:30 PM
If I pull the clutch a few seconds before shifing into 1st from N, and blip the throttle...no clunck...but that's too much trouble. I'll live with the clunck.
FYYFF!!!
Bently
2012 14r In Blue and no Mods!
posted September 02, 2006 03:39 PM
Also have the clunl from n to 1st, it's normal. other wise its smooth. 5-30 mobil one for me
nabrxx
posted September 02, 2006 04:21 PM
All hail the clunk!!!!......but what the fuck is up with the squeeky brakes?...has anyone found a fix yet, driving me nuts!
posted September 02, 2006 07:51 PM        Edited By: dubious on 2 Sep 2006 20:52
Mine got much smoother after about 3000k too.
Every bike I have ever pulled up beside, and ridden, all clunk from N to 1st.
Don't worry about it.
posted September 02, 2006 09:36 PM
+1
the click doesn't bother me either
sphynx
posted September 02, 2006 09:40 PM
Thanks for all you inputs.
PS nabrxx: I also briefly had the squeaky brakes. This happens when there is some dust on the pads, and the disk actually vibrates. Since the're floating the're more vulnrable. The reason (I think) they tend to sqeak is because the holes in the disks don't remove all the dust. The dust from the top and bottom of the pad stay while the rest of the pad is cleaned, making the problem worse. The reason it doesn't do it when new, the disk isn't smooth yet.
Anyway, quick fix is to apply front break as hard as you can without locking the front, while applying power. PLEASE BE CAREFUL!
Hope you come right. Cheers
posted September 02, 2006 11:06 PM
after reading more of your comments, you might want to retitle your topic "clunking into 1st gear" instead of "violent gear selection"... they mean two totally different things in my books.
0.22004079818726 seconds processing time
