BIKELAND > FORUMS > ZX-14.com > Thread: suspension settings? NEW TOPIC NEW POLL POST REPLY
posted August 31, 2006 10:35 PM
I've seen a lot of related threads with some experimentation....
any definitive info / settings to keep my fat ass from bottom this bike's forks out? Man... that "thwack" hurts my ears, and my feelings!
ZXLNT
posted September 01, 2006 12:42 AM
I think its just plain undersprung. New fork springs with a stiffer spring rate are needed..
FasterThanStink
posted September 01, 2006 02:32 AM
I have two turns more preload and 1 click more compression damping. Seems about right but stiffer springs with less preload and compression would be ideal.
That's what gets you.
jetman2
posted September 01, 2006 02:58 AM
I've only got about 200 miles on my bike to date. (1 week old) and was wondering about settings myself. I'm not NEAR as big as a lot of you out there at 5'9/150lbs. It doesn't seem too soft to me SO FAR but I haven't pushed it real hard either. Any of you guys/gals nearer my height/weight have suspension setting suggestions? Right now mine is as it came from the dealer, and haven't changed a thing.
Black 2006 ZX-14
posted September 01, 2006 03:45 AM
I'm scrawny and I've always felt the suspension is soft (both front and rear). I haven't done anything about it yet, and look forward to what you experts say about it. Thanks for posting this topic...
zxlnt
posted September 01, 2006 03:58 AM
The suspension is way undersprung both front and rear. That and it doesn't feel like it has enough compression damping up front. My 12R was undersprung in the back, but I go it sorted out, along with the front end. No such luck with the 14 so far..
posted September 01, 2006 04:42 AM
Start off by turning the fork spring preload clock wise 1 full turn at a time to make the forks stiffer...
Same goes for the rear spring!!!
blue max
posted September 01, 2006 05:10 AM
i want to slow the compression rate of the rear shock, what do i do?
best 9.23
zx1kr
posted September 01, 2006 06:06 AM
Turn clockwise in 1/4 turn increments on the comp. adjust screw.
zx1kr
posted September 01, 2006 06:11 AM
any definitive info / settings to keep my fat ass from bottom this bike's forks out? Man... that "thwack" hurts my ears, and my feelings![/quote
I weigh 250 w/gear. What is your weight? I'll check my settings & let you know. I've got it to the point that it RARELY bottoms. I'm going to send forks to Lindemann Eng. for a complete overload. I going to go w/ a Pense on the rear when they are available.$$$$ will hurt the wallet but, my ass will definitely appreciate it.
blue max
posted September 01, 2006 06:16 AM
is that top or bottom of the shock
best 9.23
zx1kr
posted September 01, 2006 06:32 AM
Top
posted September 01, 2006 07:32 AM
yeah, once it has some miles on it, the rear will bottom too, pretty easilly over whooped out roads.
Both ends are undersprung, and the compression damping appears to be too linear, the damping needs to be more proggressive.
It was set up for touring more than sporting from the factory.
flatoutbu
posted September 01, 2006 09:20 AM
i have the spring preload at almost full and i still bottom on hard launches...my undertail hates me
06 Blue 14
9.008 at 153mph @ 195 suited
posted September 01, 2006 09:56 AM
You need to do the above firstbefore messing with the rebound and compression on the shock!!!
posted September 01, 2006 10:00 AM
zx1kr... I'm about the same weight as you with gear on... CR... yeah, I know... I was hoping to avoid pulling out the measuring tape and doing the whole sag BS... call me lazy....
sphynx
posted September 01, 2006 10:51 AM
my 2c worth. I weigh 84 kg and done some experimenting. I found that the compromise for myself is 5 "lines" showing on the front preload. (actually found that it upsets too much by going further) , 6 clicks out on compresion, 5 on damping. For the rear, as per book recommendation. Have found the rear actually fairly sprung. As I say, my 2 c worth.
"My ambition in life I's to become the person my dog thinks I am" by rabbits losing lucky feet.
sphynx
posted September 02, 2006 11:03 AM
Just tried something. Looks like the comp and damp setting on my rear spring has almost no effect. Amazing, tapped the screw all the in and out, and very little if any change. Anyone else tries this?
posted September 02, 2006 02:22 PM
good info
0.24654197692871 seconds processing time
