BIKELAND > FORUMS > ZX-14.com > Thread: Rain in the intake ? NEW TOPIC NEW POLL POST REPLY
ShadyD
posted August 29, 2006 08:19 PM
Is there any danger of sucking up rain in a heavy down pour ? I don't go looking to ride in the rain but sometimes shit happens. I had to pour water out of my boots last time. No ill effects yet but I'm concerned !
posted August 29, 2006 08:29 PM
I've never had any probs with rain (other than the ZX14 is such a sweet bike it tries to melt)
posted August 29, 2006 08:40 PM
Any rain is gonna hit the back of the airbox and drain via the tubes. No worries. Anytime you take a high speed column of air and bend it, the moisture tends to seperate out and splat against the nearest walls.
TeamSpeed
posted August 30, 2006 03:54 AM
And a little bit of water that somehow could make it into your cylinders would vaporize.
HiMile14
posted August 30, 2006 05:44 AM
I've ridden in some serious downpours without a problem. Swft and Teamspeed +1
Rob
speedgene
posted August 30, 2006 06:17 AM
Look down on the lower left side of the bike near the shifter? Somewhere behind the fairing piece(?) you will see what looks like a clear plastic bottle with a removable plug on the bottom? Any hose you see along side that also has a plug at the end of the hose; is for water/condensation build in the post chamber-A/C cavity... due to rain, fog, etc.
Simply pull the plug, and drain whatever is in the hose? When you change oil, drain the hose(s) as well.
If you hit rain... uncap and drain. It was all designed-in from the get-go. Recap the hose, or dirt will be sucked up the tube on the intake strokes!
Besides, a little steam exploding the carbon off the cylinder chamber is a good thing.... less compression build up = less chance of engine knock.
E-tard
ShadyD
posted September 01, 2006 08:29 AM
Thanks speedgene. That is some great info. I'm going to look for the plastic bottle today. I have seen the other hoses and wondered why they had caps on them. Thanks again. I'm not worried anymore.
D
posted September 01, 2006 08:49 AM
Keeps the intake valves nice and clean - no biggie
Tool Man
posted September 01, 2006 11:19 AM
Water Injection Good for about 5hp i love riding in the rain
The banks are failing..
The banks are failing...
Invest in Ammo
nightmare
ACP Racing
posted September 01, 2006 01:09 PM
I ride in the rain a lot as wel no problems thus far
0.23823809623718 seconds processing time
