BIKELAND > FORUMS > ZX-14.com > Thread: regearing? NEW TOPIC NEW POLL POST REPLY
blue max
posted August 17, 2006 12:14 PM
regearing?
want to change front sprocket, what are my options, how much, were can i get one and how well will it help for the drags, will the stock chain work , how much will speedo be off , low buget don't you see
best 9.23
posted August 17, 2006 12:21 PM
Use the search feature. You will find lots of guys going to 16t on the front. Sprocket specialists.
posted August 17, 2006 01:24 PM
any front sproket for the zx12r will fit, slightly more wheelie prone, better roll ons,
16 tooth with stock chain ...YES,
16 tooth will be 6% out from stock readings
blue max
posted August 17, 2006 01:34 PM
does it matter if i get a factory one or aftermarket, my bike is slammed and how hard to put on, how much do you think it will help the et
best 9.23
htosado
posted August 17, 2006 01:38 PM
Hey Dubious, does the 16t take away much of the top end?
htosado
posted August 17, 2006 01:49 PM        Edited By: htosado on 17 Aug 2006 15:00
http://www.drivenracing.com/content.cfm/go/storeproduct/id/725/name/06kawasakizx14frontsprocket530
15,16,17,18 t front sprockets for the 14
Stalwart
posted August 17, 2006 01:57 PM
Stuart
Ridin' the Trump train.
htosado
posted August 17, 2006 02:01 PM
Stalwart thanks. someday you'll have to teach me that. Do you know what the top end reduction is? with a 16t?
posted August 17, 2006 07:29 PM
6% loss of top speed, with a speedo healer, you will gain top end even with a 16 tooth!
htosado
posted August 17, 2006 07:52 PM
How is that possible?
What was the locking mechanism on the nut. I know it has been re-hashed, but I'm doin mine tomorrow for the ride this weekend.
Is it reversed thread, or a lock over the nut?
posted August 17, 2006 08:02 PM
You would be best served taking it to someone to do it.
blue max
posted August 18, 2006 07:24 AM
thanks ordered today, i am a ford tech, what is involved with installation?
best 9.23
flatoutbu
posted August 18, 2006 10:27 AM
it is NOT reverse thread..its a bitch to get off but if your carefull you can do it. Find the right size socket and either a good impact or a good heafty breaker bar.
06 Blue 14
9.008 at 153mph @ 195 suited
zerMATT
posted August 18, 2006 10:40 AM
Several people have had no problems getting their nut off (sorry ), but a few have had a beast of nut and it took locomotive equipment to get off (sorry again ).
It seems like your best bet is to get a good air supply (not the band), 150psi+, a good impact wrench, 500lbs+, and a good socket. Try it a few times, but don't just sit there and beat the hell out of it forever. If you don't have any luck after a minute or so, put your sprocket cover back on and take it somewhere for some serious "persuasion".
blue max
posted August 18, 2006 11:01 AM
when i take the cover off what will happen with the slave cyl., is the nut locktited on? what about heating the nut
best 9.23
posted August 18, 2006 01:05 PM
The slave comes off with the cover, I just compressed it before reinstalling the cover.
Yes, my nut did have some loctite, I do not fully understand why, as there is a lock washer on there as well. Just unfold the washer, and upon reinstall fold a different section over onto a flat on the nut.
In any event some slight heating of the nut without heating the shaft and seal may be appropriate
blue max
posted August 18, 2006 01:41 PM
thanks, i'll give it shot
best 9.23
htosado
posted August 18, 2006 04:47 PM
I just had to make sure that the washer was pushed all the way back. I pushed back the tab, and then I could not get it off. I then had to push ALL the way around the washer to make sure nothing was stoping the nut. I then used a torque wrench it came right off.
zerMATT
posted August 18, 2006 06:36 PM
FYI - you shouldn't ever use a torque wrench to break a nut/bolt loose. Pick up a decent breaker bar for that job.
blue max
posted August 22, 2006 12:33 PM
put sprocket on , piece of cake!
best 9.23
0.35369205474854 seconds processing time
