BIKELAND > FORUMS > ZX-14.com > Thread: brocks set up questions NEW TOPIC NEW POLL POST REPLY
chris3232
posted August 17, 2006 07:49 AM
I want to get a Brock's megaphone 4-1, pc and the TRE set up. Has anyone installed this themselves. I am pretty technical. I want to install it myself. Is it pretty easy? Also are there any turning or scraping issues with this pipe.
serius blk
posted August 17, 2006 08:02 AM
know problems with the pipe setup. Good instructions and it doesnt scratch the ground. Good clearance. If you decide to buy a tre I have one still in the box that ill sale for 45bucks. I got it and then waited to long to send it back.
dbeadling
posted August 17, 2006 08:26 AM
gos on easy as cake....cant go wrong
BlackMagic14
posted August 17, 2006 11:05 AM
I installed my SMEG myself it is easiest to drop the radiator other then that a pretty easy install the hardest part was getting the stock exhuast off
tslewisz
posted August 17, 2006 11:09 AM
I didn't completely remove the rad. Just removed a bolt or two, loosened a couple of others and rotated it forward. Worked fine - plenty of room.
halvefast
posted August 17, 2006 12:56 PM
Serius- You have a PM!!
ECTA Ohio Mile 195.132mph
Bently
2012 14r In Blue and no Mods!
posted August 17, 2006 04:47 PM
Smeg is easy to install, thats what I have on mine. Save your money on the TRE and remove the flies.
posted August 17, 2006 06:26 PM
I installed a PC and Brocks Gen3. If I can do it, anyone can!!!! Thanks to raptor 14, he gave VERY detailed illustrtated directions (down to the last screw on the plastics). I found no need to drop radiator, (of course I did the Gen3 not smeg). The directions can be found at:
http://members.cox.net/allengeo/ZX-14/Installation%20Of%20Brock's%20Gen%203%20StreetSmart%20+%20PC.pdf
BobC
posted August 18, 2006 06:51 AM        Edited By: BobC on 18 Aug 2006 07:52
Me too, installing a TiForce system. I removed the lower body panels, undid the bottom radiator bracket and also removed the horn. This allowed me to swing the radiator forward without undoing any coolant hoses. There was just enough room to get a socket on an extension with a universal joint up to the exhaust flange nuts.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted August 18, 2006 07:28 PM
Per Raptor 14's directions, I didn't have to do anything to the radiator to remove the stock exhaust, or install the header for the Gen3.
0.32243084907532 seconds processing time
