BIKELAND > FORUMS > ZX-14.com > Thread: PC Installation NEW TOPIC NEW POLL POST REPLY
BobC
posted August 16, 2006 06:24 AM
PC Installation
Just installed a Power Commander. I put it below the left-hand top fairing cover alongside the air intake tube, where Dynojet say to put it in their instuction leaflet.
Personally I am not very happy with this position. Has anyone managed to feed the cables through and install it under the seat? I threaded the Speedo Healer cable through and that was pretty tight as there was hardly any room. Does the PC cable go through?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted August 16, 2006 06:30 AM
I saw at least one pic where someone put it below the seat, so it's possible. I put mine in the recommended location as well, since the Scorpio is taking up a fair amount of room under the seat.
BobC
posted August 16, 2006 07:47 AM
Yes, I remember a pic on this forum and also Brock installed one under the seat, as shown in part one of his ZX14 Diary. I wondered if they managed to plug it into the ECU somehow, rather than the connector behind the engine.
Stock wheelbase
Vegasdude
posted August 16, 2006 08:14 AM
Here you go, quite easy. You have to remove the tank though. Here is where you thread the cable through.
BobC
posted August 16, 2006 08:19 AM
Great, thanks for that Vegasdude. I'll have a go when I've got a couple of hours spare.
Stock wheelbase
Vegasdude
posted August 16, 2006 08:29 AM
That gray cable you see by the nut driver is the power commander cable already threaded through!
BlackMagic14
posted August 16, 2006 11:42 AM
I have mine installed under the windscreen it is easy to get to and is about a 15 minute install I will get some pics this weekend
zxlnt
posted August 16, 2006 12:37 PM
15 minute install? Lord it took me and a friend a half hour just to get the freaking connector plugged in. Was there a trick to it or something???
Vegasdude
posted August 16, 2006 03:23 PM
You forget, it's "BlackMagic" :P
zxlnt
posted August 16, 2006 03:49 PM
Ah ok, thanks for the headsup
posted August 16, 2006 07:24 PM
VD - I think it took me bout 15 minutes as well. Really easy...Maybe you needed 'more pictures'??
ZXLNT
posted August 16, 2006 07:59 PM
Vegasdude can you help out on that???? ^^^^^^^^^^^^^^^^^^
zxbob
posted August 16, 2006 08:10 PM
vegasdude
posted August 16, 2006 08:56 PM
BlackMagic14
posted August 16, 2006 10:43 PM
You have to use a mechanics pic to push the pin down and you pull on the wire not the actuall connector should take about 10 seconds to get the connector apart... Also if you install under the windshield I recommend zip tying the PC to the bracket so it doesnt rattle around
ZXLNT
posted August 17, 2006 12:15 AM
I see the trick, we didn take any bodwork off except the grills I dont think. Couldn't hardly get hand in there to get at connector...
Vegasdude
posted August 17, 2006 08:22 AM
Lazy!
zxlnt
posted August 17, 2006 10:25 AM
Not lazy, just not well enough informed..
posted August 18, 2006 06:50 AM
Yah, I did have the factory manual, so removing the panels was a snap.
Vegasdude
posted August 18, 2006 10:48 AM
Heck, I'm lazy.........if I could get away from not taking the panels off..................I sure wouldn't!
MarkVic
posted March 01, 2007 09:34 PM
If you take out the tool box it fits in it's place well and there is room for a Scorpio alarm to boot! I couldn't see any reason to keep the tool box anyway 'there are few items you could actually work on on the road with the tools provided.. I found a large spanner wrench with an expandable handle.. which did not fit anything?, It is too small diameter to fit the rear axle nut.. What is this for? ( Mark on the coast of Texas)
MasterBlaster
posted March 02, 2007 06:59 AM
Put mine under the windscreen also, I have one of the early Muzzy modded PCs. Ran the ground wire to the left side ram air attach bolt. Eveything fit like it was designed to mount this way, and very easy to get to....TB
MarkVic
posted March 02, 2007 07:08 AM
jYea But it is much easier to get to under the seat. You only need a key to get the seat off.. You have to remove screws and a plastic panel the other way...
0.23400092124939 seconds processing time
