halvefast
posted August 14, 2006 03:22 AM
Avon Tire Promo
http://www.avonmoto.com/contests/contest.asp
ECTA Ohio Mile 195.132mph
droid
posted August 14, 2006 08:34 AM
Nice tyres got them on me 12 wear well and good levels of grip!
bbirdxx2000
posted August 14, 2006 10:49 AM
quote: Nice tyres got them on me 12 wear well and good levels of grip!
How many miles do you expect from the rear
9.96 @ 143 stock with flies removed
tuusinii
posted August 14, 2006 11:01 PM
My experience with Avon (st45/46) and ZX12 was the most freightening on any rubber. They vere hadr to turn and feedback from front was bad. And the worts thing was that in wet they were like riding on a ice! Yes they lasted good but maybe only 30% more than Michelin Pilot Sports or new Pirelli Diablos that are much better when actually riding. If You ride in wet don't go with the Avons!
posted August 14, 2006 11:07 PM
^^^^ heard this many times from several members. ^^^^
zzr1400
posted August 15, 2006 01:52 AM
Edited By: zzr1400 on 15 Aug 2006 02:58
... from several members and if not convinced, see for yourself on Motorradonline tire-test that Avon is last placed of 7 in 2004, 2005 and 2006... Metzeler and Michelin are #1.
http://www.motorradonline.de/static/specials/ReifenSpezial/Reifentest2004/sport/Gesamtwertung.html
http://www.motorradonline.de/static/specials/ReifenSpezial/Reifentest2005/img/kriterien.html
http://www.motorradonline.de/d/214372?&ref_id=214321
halvefast
posted August 15, 2006 07:26 AM
Edited By: halvefast on 15 Aug 2006 08:28
OK here is a reveiw I found on the Conti Road Attack:
Product Reviews
Continental road attack's
I must admit a level of trepidation over testing a set of Continental motorcycle tires. In the past, my only context with Continental tires had to do with London motorcycle messengers choosing them because they wear like iron. However, I was given reassurance such as "they are one of the top selling tires in Europe " and "They are rumored to grip like Pilot Powers and last like Pilot Roads". Both statements worked to calm my anxieties. After all, its not like Continental is new to the tire business. And the Road Attack was recently named as the offical tire for the new BMW's...
I was given a quick briefing about the structure of these German made tires. They use a similar construction as Metzelers, but instead of just coiled steel belts wrapping the carcass, these tires use braided belts which supposedly prevent the tire from deforming during cornering and acceleration. This results in the rear tire providing a larger footprint than traditional tires, thereby giving more grip. Also, less deformation means the tire builds up less heat, and a softer/grippier rubber compound can be used. I was advised, however, that the tires should be run at higher air-pressures than what we have become accustomed to. I was advised to run 41-42 in the rear and 35-36 in the front.
The tires have a few cool features about them, besides just the really cool tread pattern. All the sidewall writing is up-side-down from traditional tires, and there is a cool, wavy checkered flag pattern that wraps the sidewall.
Unlike many motorcycle tire tests, where the magazine guys run a few laps around a track then give their impression, out test was a run-em' to the nubs sort of test where we'd see how they behaved over a long period of time and, hopefully, over a plethora of riding conditions.
Two rear tires later (and one front at about the end of its usefulness) I feel that we have a very fair report about how these tires behave. Additionally, because we have worn out a lot of the competitors tires, I feel safe making some generalized comparisons. However, be warned that actual mileage may vary.
First, I had an initial hard time getting used to the tires profile. They are different from anything I had run before. The tire tips in really quickly, but then the more you lean, the slower they tip in. This was weird at first, but after a few thousand miles on them, I don't want to go back. It is the unique profile of these tires that makes them shine. Extremely stable while going straight, similar to a Metzeler, really quick and light on the initial turn in, very similar to a Pilot Sport, but progressively more stable and planted as lean angles increase. I found this to inspire additional confidence.
Kris' Z1000 and the Speed Triple both call for 190 width rear tires (somewhat controversial because many feel that 190 tires have slow turn in) I can assure any rider that slow turn-in is not a problem. Much to my delight, I've yet to lean the bike all the way to the edge of the tire; a very comforting fact after riding other tires where I'd feather the edges going to the gas station. The rear tire also seems to exhibit the same light and planted turn in feel common in the smaller 180 width tires. This is a huge improvement from what I would describe as the lethargic feeling Pilot Roads.
Additionally, they are very communicative tires, which may be a love or hate characteristic depending on the rider. Where the Pilot Roads are almost numb by comparison, the Road Attacks communicate every weird road surface to the rider. I feel like I know exactly what's going on. The Pilot Roads are kind of an "ignorance is bliss" kind of tire where nothing is felt until the tire starts to slide. The Conti's are a "knowledge is power" sensation.
Unlike Bridgestones, (also known for a stiff carcass) the Conti's do not sacrifice ride. The Bridgestones I've ridden tend to provide a very harsh ride where even the smallest bumps are felt all the way to my fillings. I suspect because the Conti's use a zero-degree belt, just like Pilot Roads, Metzelers and Pirelli's, the tires provide a very predictable yet smooth ride. The tires have never had a jarring sensation like the Bridgestone BT020's and BT010's.
But all this is moot if the tire does not inspire confidence in the ability to grip the road. The Conti's excel, well beyond my highest expectations. While I've never run Pilot Powers, I do not feel qualified to make a straight comparison, but I have worn out a few sets of Sportec M1's and I can safely say that the grip is comparable to the Sportec's. They feel like they will stick to the ceiling.
Wet road grip was another concern, but we've run these tires on moist coastal roads, through torrential down-pours, through fog across the desert, in the freezing cold morning and in the mid-day heat. They have only once, in over 8000 miles slipped on me. And that slip took place when I was accelerating hard in a heavy rain-storm over a fresh stripe of paint; and what tire wouldn't slip in that situation?
Even after two road trips (two separate rear tires) the Conti's were reluctant to show a flat spot in the center of the tire. While you could certainly see that they were wearing more down the middle, the tire kept is shape. I've never ridden a tire over as much flat, straight road as these two Conti's and I'm thrilled with how much mileage I've gotten out of them, particularly when I think of how well they grip. The rear tire looks like it will last about 6000-7000 miles (where the Pilot Roads were lasting me around 5000).
The tires are not without some faults. I installed the lower profile 120/60 front tire, which I think was a mistake. The lower profile front feels a bit skittish, but the OEM sized 120/70 front on Kris Z1000 exhibits none of those traits. My advice would be to get the taller 120/70 front tire.
The Road Attack front tire has worn, almost, too well. The "Conti Attack" text is still readable down the center of the front tire, although the sides are rubbed down to the wear bars. Tires do not generate as much heat when traveling straight, so I can only assume this is the reason, but it makes me think that a Conti Sport Attack front tire would be a better option.
I must say though, the more I ride on these tires, the more I like them. The more I get accustomed to what the tire is telling me, the better I feel about throwing into a corner, or holding back a bit and they are tires that I'll happily plunk down my own stack of George Washington's for.
I would go so far as to say these are the finest road tires I've run (I've even had them out for a couple of track days!). In fact, I purchased a set and threw them on Kris' new Z1000. And based on my recommend, three other people have installed sets, that I know of, and have reported the same very positive comments about the tire.
The lower price tag also makes you feel better about just riding the bike. A 190 Pilot Road retails for over $200 while the same rear Conti's retails at about $160! And in my opinion, the Conti is a better tire than the Pilot Road and the Metzeler Z6 in every way! It grips better, handles better and lasts about the same as the Pilot Road and way better than the Z6. Find out more at conti-online.com
__________________________
w w w . c a n y o n c h a s e r s . n e t
suicycle
posted August 16, 2006 12:50 PM
I have never run any of the ST (sport tour) Avons. But I have run their performance lines before. I have run both Azaro and Venom Avons on my other bikes and they have been great. In fact this months Performance Bikes (a euro publication, readily available here in the U.S.) the latest Avons, the Viper, Finished number 2 in the tests. The standard Azaro and Venom tires lasted almost 5000 miles on my other big bikes, and yes I ride them very hard. And I say they because they actually wore out a front and rear set at the same time (never had that happen with any other tires (usally at least 2 to 1 rear to front and usally 3 to 1 rear to front). I have worn out a The rear on my 14 already and it only has 2500 miles on it, its pretty much gone edge to edge now (new one on order). I will keep putting Bridgestones on the back until the front wears out, but after that most likely the latest Avons for me.
suicycle
posted August 16, 2006 12:55 PM
Oh yeah. And yes I have ridden them in the rain with no complaints (I mean heck they are a British company...and Britain does see just a bit of rain LOL). Just make sure to get the supersport compounds...the race compounds dont wear well....stickiest tires I ever ran but least amount of wear of any tires I've ran also.
droid
posted August 17, 2006 01:19 PM
quote: My experience with Avon (st45/46) and ZX12 was the most freightening on any rubber. They vere hadr to turn and feedback from front was bad. And the worts thing was that in wet they were like riding on a ice! Yes they lasted good but maybe only 30% more than Michelin Pilot Sports or new Pirelli Diablos that are much better when actually riding. If You ride in wet don't go with the Avons!
I see you are quoting a completely different tyre to the offer, the 45/46's arent like the VIPERS,
I have always run Avons on my mcycles, yes the Azaros were a little twitchy, but not hard to turn. If anything they suddenly drop in as you run off the profile, and as for your don't go wet with Avons I rode home yesterday in torrential rain with no problems....on the VIPERS, half the time tyres aren't the problem in the wet it is the road surface.....you ram 170hp through a contact patch the size of a lemon and add greasy roads what would you expect!!
