BIKELAND > FORUMS > ZX-14.com > Thread: FYI NEW TOPIC NEW POLL POST REPLY
posted August 10, 2006 05:44 PM
FYI
Just in case anyone wasn't sure, the ZX12R and ZX14 are different bikes...
What will swap from the 12R to the 14:
Front tire (Rear is a 190 on the 14, 200 on the 12R)
The stabilizer part of a Scotts
Horn
Umm...can't think of anything else!
What WON'T swap:
Fairings
Brakes
HeliBars
Exhaust
Seat
Rear Tire
Headlights
and the list goes on and on...
lietoome
posted August 10, 2006 06:19 PM
pegs swap out. I put the black Powdered pegs from my 12 on the first day.
Is hole in the steering stem the same?
Swingarm bolts(for spools) same MM?
What about the heelguards?
I think I'll measure it. Anyone tried any of these?
Scotts damper from a 12 will work on the 14?
posted August 10, 2006 06:48 PM
Sure, the mounting kit will be different, but you can use the dampner.
posted August 10, 2006 06:57 PM        Edited By: dubious on 10 Aug 2006 19:58
throttlemiester bar ends, and countersproket are the same
posted August 10, 2006 07:19 PM
There ya go. Swingarm spools too
posted August 10, 2006 07:23 PM
My butt fits both of them... does that count??... Sorry i could not help myself.. Plus it helps my post count...
posted August 10, 2006 07:54 PM
you fit swingarm spools in your butt??
lietoome
posted August 10, 2006 08:04 PM
just took the Powdered heelguards off my 12 and put them on the 14. They look SOOOO much better than the damn funky shaped ones on the 14.
I feel like a real bastid stealing from my 12.
swapped the pitbull spools too.
Measured the steering stem hole---they are the same.
GUNNER
posted August 10, 2006 08:11 PM        Edited By: GUNNER on 10 Aug 2006 21:12
AND YOU SHOULD FEEL THAT WAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
lietoome
posted August 10, 2006 08:19 PM
It's temporary.
Everything 'borrowed' from the 12 will be replaced. THe 12 is also getting some non-avon tires(pilotpowers) and some fresh powdercoating.
why? the 12 cant hold a candle tot he 14.
lietoome
posted August 10, 2006 08:26 PM
My 12 was my first bike, so its kinda like cheating with your girlfriends best friend.
I didn't regret either situation for long.
0.30311608314514 seconds processing time
