BIKELAND > FORUMS > ZX-14.com > Thread: Heard loud clicking?? NEW TOPIC NEW POLL POST REPLY
ny28av
posted July 31, 2006 07:09 PM
I was in 1st gear @ about 4k rpm, popped the clutch to do a wheelie, and i heard a loud clicking noise like i was stressing something out. i was in a parking lot messing around, so i repeated it a couple of times and heard it again almost every time. Any ideas?
3Boysand3Bikes
posted July 31, 2006 07:17 PM
Sounds like a 'cush' drive situation... your rear hub is made to have some 'give' to it... but when it is wrenched a few times it loses strength.. The chain then doesn't mesh well with the sprocket.. I am not sure... but in my youth I can almost word for word repeat your story, and everytime I was able to fix it with a new cush drive.
That is just one idea... I am taking into account the fact that you have checked your chain tension, sprocket teeth etc??!! I am sure that the more mechanical endorsed members will be able to shed some other light... Just a thought from my experience... OH.. and lastly... I wouldn't do that anymore... lol Good Luck!
northmedic
posted July 31, 2006 07:22 PM
was your bike still cold ?
I,ll be right back
extremelean
posted July 31, 2006 07:23 PM
Loose chain....chain is trying or IS climbing over the teeth of your rear sprocket.
Check and see.
ny28av
posted July 31, 2006 07:25 PM
yeah, the sprockets look okay. the chain has streched a little since new (2500mi.) yeah, im not gonna beat up my baby anymore. i'll save it for the R6. do u think i gotta replace this "cush" thing?
ny28av
posted July 31, 2006 07:26 PM
yeah, i bet its the chain
3Boysand3Bikes
posted July 31, 2006 09:19 PM
Get the chain adjusted good before you worry about the cush drive... Normaly the cush drive can take a lot of abuse.. but I did have one defective on my zx-11.. I replaced it and shoed my dealer that it was a bit deformed... they actually reimbused me!! 2500 miles with heavy clutch wheelies can wear them down... but to be honest, I haven't checked if the 14 even has one. If you get the flies out... and get a PC you can do power wheelies and it is much better on everything.. (except the front seals if you come down hard! lol)
posted July 31, 2006 11:55 PM
Did you ever open the clutch???...If so then bleed the system...
It's most likely what the others said about the loose chain...
kawasaki_rick
posted August 01, 2006 02:28 PM
Could be the front sprocket. Mine was clicking under hard accel. I replaced it with a steel sprocket. Now no clicking. The factory has the rubber mounted sprocket.
warbird
posted August 01, 2006 03:13 PM
Usually the loose side of the chain slapping the swingarm. If it gets too loose it WILL jump around on the rear sprocket like extream said...........not good..........
I'd Rather Be Roadracing.
warbird
posted August 01, 2006 03:20 PM
When my Busa was new it stretched the chain to that point ( that sound you heard ) on my third run at the dragstrip. Suprised the heck out of me when I heard it. Aborted the run, went back to the pit and couldn't believe how loose the chain was. The big bikes ZX14/Busa/12)
can do that to a chain REAL fast when they are new...........:wink
0.21513104438782 seconds processing time
