BIKELAND > FORUMS > ZX-14.com > Thread: Those with a muzzy full system NEW TOPIC NEW POLL POST REPLY
oj330i
posted July 29, 2006 09:05 PM
Are you experiencing a loud pop and shooting flames on deceleration at or around 3.5K rpm? I am and another guy I know is expierencing the same problem. I have a cali model with the charcoal filter installed and I'm still expericing the same pop and flames on decel. Anyone have a fix for this yet?
Mods: Muzzy full Ti/Ti 4 into 1, PC3, Mirror Block offs, Muzzy frame sliders, custom undertail, vortex rear spools.... more to come
Current:
'06 Candy Blue ZX-14
'03 Silver/Black R1
Former:
'03 YZF600R
Vegasdude
posted July 29, 2006 09:17 PM
Has your airbox been blocked off?
oj330i
posted July 29, 2006 09:20 PM
Nah, no airbox mods have been done so far.
TJ
posted July 29, 2006 09:23 PM
There are a couple of fixes available (plugging the hose, block-off plates, etc...). Try the search function and you will find a good number of threads discussing this issue.
http://www.bikeland.org/board/viewthread.php?FID=27&TID=25151
Vegasdude
posted July 29, 2006 09:45 PM
That's what I meant, plugging the hose on lower right side of airbox...........
scificanada
posted July 29, 2006 09:56 PM        Edited By: scificanada on 29 Jul 2006 22:56
Got my Bike back today from shop, Brock Ti, PCIII and exact same thing... 3800 to 3750 on de-cell, major pop and some flame.
When system installed, told by Kawi Mechanic that Canadian Model has no hose to block off...
Be a predator, not prey.
2006 Blue(the fastest colour) ZX14, Brock Ti Gen 3, Secondary Butterflies out, PCIII with Brock Map, Muzzy Frame Sliders.
fastestbusaaround
I eat Fish...
posted July 30, 2006 02:58 AM
SCIFI...my bike is Canadian...and the hose is blocked off now...he's fulla poop
FYYFF!!!
posted July 30, 2006 04:55 AM
I have a Muzzy pipe and i have a big pop around 3500 on decell ....But i like it!!!! See them Busas are behind me at the track and when it pops they can see just how far ahead i am ....LOL It's really a Busa warning system ...
zerMATT
posted July 30, 2006 05:22 AM
The Muzzys kit includes the kleen air block-off plug, and instructions to install it. Why don't you try that...
dbeadling
posted July 30, 2006 07:02 AM
check your popper valve...it s popping
Road Rash
posted July 30, 2006 09:44 AM
Instead of blocking off a good system why don't we take off the rear blow by hose and just vent it to the outside.
hampton strangla
posted July 30, 2006 10:48 AM
sounds like a very intelligent answer. can anybody back up his statement?
1993 gsxr 750 (sold)
1996 gsxr 1100 (sold)
1997 Honda CBR 600 F3 (sold)
2001 Yamaha FZS 1000 (RIP)
2005 zx-10r
2005 gsx1300r
2006 zx14 (hopefully someday)
  Ignore this member    Click here to send Hampton Strangla an AIM message.
vegasdude
posted July 30, 2006 11:01 AM
Because it sounds like they don't want any more air in the system
posted July 30, 2006 11:04 AM
You aren't 'venting' anything. The purpose of the KLEEN system is to inject additional air into the exhaust stream to enhance the combustion process and produce cleaner emissions. When you put a aftermarket exhaust on the bike, this results in the popping you hear when you are shifting gears or decellerating. By blocking the system, you prevent this additional air from entering the exhaust system. The reed valves that allow this action to happen are in the combustion heads and DRAW air in. If you were to VENT, you would in fact, be inducing a large vacumn leak into the airbox.
Road Rash
posted July 30, 2006 01:48 PM        Edited By: Road Rash on 30 Jul 2006 15:11
Take off the front hose by #4 start the bike. this hose has a vacuun on it. Rev it up this hose still has a vacuum on it leave this hose hooked up to airbox. Take off the rear hose(blow by) it is on the left side by the little tube that when it shows oil in it you take off the little cap and drain it. Run the motor holding your finger on this hose this hose will build up pressure. Block off the metal pipe that is sticking out of the airbox rear and just let the blow by vent the to outside. Front pipe takes the air from the air box ,rear pipe lets it back into the air box not exhaust system right. or am I wrong again.
posted July 30, 2006 03:31 PM
The crankcase vent and the KLEEN are two different systems. One has nothing to do with the other.
Road Rash
posted July 30, 2006 06:25 PM
OK so the clean air system is just a bogus system and uses the venturi affect to draw clean air into the exhaust system to make it look cleaner for emissions. The shop manual does not make this clear. Thanks.
zxlnt
posted July 30, 2006 09:24 PM
On decelleration a vacuum signal opens the Kleen air valve, that lets the air flow thru the reed plates into a small port in the exhaust port area. That mixes with the unburnt gases to further combustion and reduce emissions. Like SWFT said..
Road Rash
posted July 31, 2006 06:39 AM        Edited By: Road Rash on 31 Jul 2006 07:41
ok ok I get it. Puts air into exhaust to help finish off burn, doesn't hurt performance helps make the air cleaner for our kids to breath. Thanks I will leave mine alone.
Squareman357
posted July 31, 2006 08:28 AM
I like the flames LOL! Looks cool at night, or so I've been told by those following in my wake...I've also seen them coming from a Hayabusa with Microns and thought it looked pretty cool. Some folks have actually installed a spark plug on a wired connection just to do much the same thing.
Keep the shiny side up!
Square
'06 Ebony Metallic ZX-14 - "Delilah"
'02 Silver CBR1100XX - "Stormcloud"
'04 GS500F - "Wife's Bike"
  Ignore this member    Click here to send Squareman357 an AIM message.
posted July 31, 2006 08:37 AM
Exactly. That's a '50s rodder trick. Put a spark plug in the exhaust near the tip and it would always ignite the unburned exhaust gasses
Road Rash
posted August 01, 2006 12:42 AM
oj330i sorry to hijack.
Swft thanks for keeping me on track. Could no leave it alone so I hooked up the gages to air suction valve hose. Found it had vacuum on it at idle, when rpm went up or when they came down. What did happen was the mercury jumped up a bit when rpm went up but quickley came back to where it was at idle 6cm. When the throttel was shut down there was a loss of mercury but once again it returned to about 6cm. I feel that the air suction valve is more like a regulator that keeps the vacuum at a given.
I feel the air is pulled into the system by the venturi effect. When I took of the exhaust manifold I found each port had two passage ways one was clean and one was not. Hear is where the effect takes place and the clean air is pulled into the exhaust manifold and mixes as you said.
It just does not makes sence to me that the system would only work on decel.
Sorry to drag this out.
Road Rash
posted August 02, 2006 03:23 AM
Sorry oj330i I just trying to learn more about what this beast realy is and how it realy works. To answer your question if it were me I would just leave the system hooked up. It does not hurt performance and if you let off the throttle easey it does not pop on decel.
0.24196004867554 seconds processing time
