BIKELAND > FORUMS > ZX-14.com > Thread: Secondaries Again!! NEW TOPIC NEW POLL POST REPLY
THEMADKAW
posted July 09, 2006 11:58 PM
Secondaries Again!!
If removing the plates makes the bike too violent down low. Has anyone thought about maybe trimming them or drilling them to allow a metered amount of airflow? It would seem that that would give you the best of both worlds.
Any thoughts?
Brock?
Anybody?
TeamSpeed
posted July 10, 2006 04:01 AM        Edited By: TeamSpeed on 10 Jul 2006 05:02
That was one of my first suggestions, take the butterflies off, machine off a bit off the end from each butterfly so that you get more air through than normal, but they still offer a bit of a restriction, then put them back on again. The general consensus is to just leave them off entirely and map around it all.
My problem is that if I had all that torque down load, I travel in an area where there are ton of road projects and building construction (crap everywhere it seems, all in the wrong spots too), so that much torque, even if managed by a careful hand could get you in trouble. That is why I was looking for either an electronic solution or a partial removal of the butterfly valves.
EASY
posted July 10, 2006 04:14 AM
It does not make it "too violent down low). Just gives you the ability to accelarate hard without twisting the throttle very much----kinda like a geared, piped and mapped Busa.
  Ignore this member    Click here to send EASY an AIM message.
Jack69
posted July 10, 2006 11:54 AM
Dynojet only shows a Zero Map and a Stock Map.
Where do you guys find the Custom maps?
I have a PCIII-USB on the way and Area P Slipons on my bike. I want to pull the flys but need the maps first.
So, where do you get them?
'03 Mille Silver - ZX-14 Blue
EASY
posted July 10, 2006 12:07 PM
You have to have it custom mapped by a tuning center with the right software and dyno---costly, time consuming but worth it.
Jack69
posted July 10, 2006 12:26 PM
I was sort of hoping for a forum with an FTP site.
fastestbusaaround
I eat Fish...
posted July 10, 2006 06:57 PM
That won't help ya...you have to custom map for that....
FYYFF!!!
0.21633815765381 seconds processing time
