BIKELAND > FORUMS > ZX-14.com > Thread: Front Sprocket Removal NEW TOPIC NEW POLL POST REPLY
chez
posted July 04, 2006 04:37 PM
Did anyone else have a hard time getting the front sprocket loosened? What did you use? I found a 25mm socket fitted and used an L bar and a 3ft length of pipe as a lever.My daughter was employed to stand on the rear brake lever for the price of a movie ticket. Would like to hear of any other options in loosening this.
Chez
  Ignore this member    Click here to send Chez an AIM message.
Drowland
posted July 04, 2006 04:43 PM
use a breaker bar. Take a pole wrap with a towel and put it in your wheel so it want turn. Then put some balls into it....
dbeadling
posted July 04, 2006 04:44 PM
air gun
posted July 04, 2006 06:31 PM
+1
jimzx9r
posted July 04, 2006 08:03 PM
Save yourself the hernia and do it with an impact wrench.
Drowland
posted July 05, 2006 03:17 AM
Impact wrench wouldn't even work on my bike I had to use my first posted method
vozizm
Got Nothing Witty To Say
posted July 05, 2006 04:47 AM
what size ya changed it to?
zerMATT
posted July 05, 2006 05:18 AM
*big* impact wrench...
Mano 2
posted July 05, 2006 05:30 AM
Heat carefully to loosen threadlock compound.
jimzx9r
posted July 05, 2006 05:17 PM
Time to get a bigger impact wrench.
chez
posted July 10, 2006 04:20 PM
Got it unone finally.....tried a 2.5hp compressor, didn't budge.... Went to a truck place and used 180lbs of pressure!!! That did the mutha... Torque spec is 90ft lbs and there was no locking agent on it.
Chez
posted July 10, 2006 10:09 PM
unfold the tabs on the lockwasher, 25mm socket, 2 ft jonnson bar... brake applied,
easy as cake..
Really, i could have loosened it with a 3/8 " ratchet!
posted July 10, 2006 10:11 PM
PS.
I'd be carefull using a torch, could burn up the countershaft seal!
And to make it even better..........Oil on the rear tire would not be good!
RAC4IT
Bergie
posted July 11, 2006 09:45 AM
Chez- any 2.5hp compressor will do the trick as that has nothing to do with it, that's plenty powerful, what you're lacking is air pressure. Get an adjustable pressure regulator on your air compressor and increase the pressure to the impact gun, it should bust it loose no problem.
0.25050806999207 seconds processing time
