BIKELAND > FORUMS > ZX-14.com > Thread: exhaust systems NEW TOPIC NEW POLL POST REPLY
wrrhodes
posted July 02, 2006 12:35 PM
exhaust systems
I WOULD APPRECIATE AN EXPLANATION AS TO WHY A 4 INTO 1 WILL ALLOW THE ZX14 TO MAKE MORE HORSEPOWER AND TORQUE THAN A 4 INTO 2. THANKS
Ojref
posted July 02, 2006 03:27 PM
Because you can hump one hole faster than two.
2006 Kawasaki ZX-14 Ninja, Red now with mo' Brock's in my lyfe
1991 Yamaha Vmax - Because I need a mule to carry the manhood
2002 Ford Lightning - Ford GT Aluminum block engined, 802HP 911TQ now WhippleCharged
posted July 02, 2006 03:41 PM
Because noone makes a full 4 - 2 system?
Stalwart
posted July 02, 2006 03:52 PM
Properly designed, a 4 into 1 will give better scavenging of the cylinder. Read from the link below for a description.
http://www.ssheaders.com/header.htm
Stuart
Ridin' the Trump train.
Tool Man
posted July 02, 2006 03:54 PM
First KILL THE CAPS. Second. A 4 into 1 system work more efficiently by the scavenging (meaning sucking) of the exhaust out of the tubes. As the full one pushing its load of exhaust out it in turn pulls any remain gases out of the other three there by creating a partial vacuum. Then as the next exhaust valve opens and hot gasses are being pushed out by the piston on the exhaust stroke of the motor, they are also being pulled out by the partial vacuum. 4 into2 systems do not have the same effect.
The banks are failing..
The banks are failing...
Invest in Ammo
Ninja14
posted July 03, 2006 09:56 PM
Now when he realizes that dragsters have just short zoomies he will be totally confused.......
but they hit it on the head - it is about creating and maintaining flow out.
0.22417712211609 seconds processing time
