BIKELAND > FORUMS > ZX-14.com > Thread: ? on shifting NEW TOPIC NEW POLL POST REPLY
Bently
2012 14r In Blue and no Mods!
posted June 27, 2006 06:07 PM
? on shifting
My bike shifts harder from 1-2-2-3 gear change then3-4-4-5-5-6 is smooth. has anyone else noticed this same thing, and it clunks pretty bad going into 1st from neutral. Just getting some other feedback. not complaining or to worried about it. And how is your bikes for valve noise?
MATTZ14
posted June 27, 2006 06:31 PM
Mine sometimes is real smooth going n-1, sometimes I have have to slip the clutch to get it to go in @ all, sometimes it drops in hard. Haven't figured it out yet. RPM's, bike position, how it was parked, etc. Anybody else?
Later days, better lays
07 BLACK ZX14 Getting customized waiting for the white stuff to go away
06 BLACK ZX14 GONE Recall was a little late.
MATTZ14
posted June 27, 2006 06:37 PM
On a similar thing mine wants to jump if you start it in gear(clutch is bled), and the clutch seems really noisy when idling not engaged. Soon as it is engaged it quiets down. The dealer says thats normal for Kaws. I don't remember my old 1000 doing that but thats a different system.
zx61114
posted June 27, 2006 06:42 PM
Shifting between 4000-6000 rpm is rough. Riding at 5 am I'll shift at 3200-3800 rpm and it's pretty sweet but akward. Normal day riding shift over 6000 rpm at least 1-2-2-3 and it's smooth as well.
ZZR
posted June 28, 2006 12:03 AM
Exact same things as mine. Also shifting n-1 mostly sounds extreme hard and loud.
My dealer also said it's not unusual for big bikes. But my ZZR-1100 didn't have these probs.
  Ignore this member    Click here to visit ZZR's homepage.
sj1400
posted June 28, 2006 01:24 AM        Edited By: sj1400 on 28 Jun 2006 02:25
This weekend i noticed mine engages from neutral to 1st louder then usual - loud clunk.
zx61114
posted June 28, 2006 04:45 AM
While in Neutral, drop the clutch pull in the clutch about 3/4-7/8th of the way . Mine slides into first gear as if you were riding.
Note all bets are off if your talking about a cold engine, can't help you there, mines clunky as well.
shawnski
posted June 28, 2006 06:17 AM
mine does the same, very noisy from nutural to first gear.
ZREXER
posted June 28, 2006 06:50 AM
If your bike seems excessively clunky going into first, check your idle speed. If it is on the high side of the normal idle range, often you can get rid of most of the clunk if you turn your idle speed down a little.
shawnski
posted June 28, 2006 06:54 AM
mine idles around 1000, is that good?
sometimes i noticed when i tighten the chain to normal adjustment, it helps on smoother shifting.
Bently
posted June 28, 2006 08:30 AM
All good points, mine is at 1000 for idle as well. Chain feels about right on as well.
0.23559617996216 seconds processing time
