BIKELAND > FORUMS > ZX-14.com > Thread: Still no 9 but went 10.09@141 NEW TOPIC NEW POLL POST REPLY
Bently
2012 14r In Blue and no Mods!
posted June 25, 2006 12:37 PM
Well I'm still searching for the nines but did go a 10.09 at 141. was running in 86 percent humidity and temps in the 80's so I know that's costing me, but not sure how much. Still could only manage a 1.745 60 ft. If I can get in the 1.60's I know a nine is there. really wish I was not 218 unsuited right now.
iflyphi
posted June 25, 2006 12:41 PM
That's a great time, but a crappy 60' time. These bike are a bitch to launch. I could only do a 10.27 at 200 pounds suited, but a 1.70 sixty foot time, and only 135mph. It was 90+ deg, and about the same humidity, typical for southern Louisiana.
The questions everybodys gonna ask; Was the front end strapped down(mine wasn't), where the fly's in(mine were), do you have an exhaust or powercommander(I didn't).
Bently
posted June 25, 2006 12:52 PM
Bike is bone stock, no strap and the tool kit under the seat. And I'm probably 240 suited up. iflyphi you are running some low mph, I never run below 139.50.
Mano 2
posted June 25, 2006 01:26 PM
Iflyphi,
Thanks. I was thinking it was me.
Esp since my 12 launched so easy...
I haven't been to the strip yet. We'll see then for sure.
FlatoutBu
posted June 25, 2006 03:02 PM
That sounds almost identical to my times. But i had a 1.70 sixty and a 10.06 at 138. I'm 235 with all my gear on...800ft elevation, 80 something degrees and 80% humidity. I ran this number 3 times and couldn't improve on it. Now heres the funny part...put on a full Brock exhaust ,power commander and a airshifter and could only go 9.91......but, had a 25mph headwind and i pulled the throttle plates with brocks map. It looks like it's running rich but it go's on the 8th of next month to schnitz where Ryan will put a tune on it. This coming wednesday i'll be back at the track and hopefully with no headwind we'll see what it can do.
06 Blue 14
9.008 at 153mph @ 195 suited
Bently
posted June 25, 2006 04:03 PM
Flatoutbu, I'm curious what you will run wednesday, please post. As I was thinking about goung with a brock system. But hope for more then a 9.91. What was your 60ft with the brock system?
posted June 25, 2006 04:29 PM
Nice going Bently ...Don't worry 9s are just around the corner ....... My first three times to the 1/8 mile i got faster with each visit .....first time out 6.40s@114 second time 6.30s@117 third time 6.21@119 ...... You just need more seat time not more power....Keep going and with more passes you get you will get faster ... I was going this Sat night be we rained out and we rain out last Wensday night also ..... I think i would have been in the 6. teens , damn rain outs !!!! Don't worry about them 60 times, 1.70 will get you 9s .... More important than the 60 is the 330 time .... Look for your 330 cone on your track and use it to judge when you pin the throttle.... Each time you make a pass make a note on that and try to get the throttle pinned earlier....The 60 times will get lower the more passes you make and kind of fix their selfs ......After the 330 work on you shift points, making sure you shift right at red line each shift ....I know you are a big guy but you need to tuck in as tight as you can and as soon as you can....Maybe a double bubble screen would help you with that....
Brock
Sponsor
posted June 25, 2006 04:56 PM
Any Brock's customer who did not automatically receive new maps should fill out a map request form:
Subject: MAP SUPPORT REQUEST FORM -
STREETSMART OWNERS GROUP (PRIVATE) ACCESS PROCEDURE
Thank you for you order and WELCOME to our program!
Please Click the following:
1. Brock's Performance
2. Click: Map Support
3. Fill out and submit the form
Once the MAP SUPPORT REQUEST FORM is completed...you are officially in our secure system. Approval usually takes 1-2 days.
Note: if you have trouble logging on or registering, your browser may need to be reconfigured to accept cookies.
Go here for login help: http://www.brockracing.com/forum/display_topic_threads.asp?ForumID=18&TopicID=139&PagePosition=1
Sorry for the delay, we guard our information to protect our customers from others using it against them!
Special Note:
Once your membership is approved, you will receive FREE map support for as long as you own your Brock's Performance exhaust system. Stock to highly modified...we have a map for you!
If your combination changes later (add cams/pistons etc.) simply re-submit the form:
Brock's Performance
Good Luck and enjoy your new Speed secrets.
Brock's Performance Staff.
  Ignore this member    Click here to visit Brock's homepage.
posted June 25, 2006 04:59 PM
Nice ETs guys...The more you go the better you get...Remember open that throttle!!!
bbirdxx2000
posted June 26, 2006 02:29 AM
Great run, I weight the same as you. I have a 16-T Sprocket and stapped. Went 10.15 @ 139 60' @ 1.70. I actually think the smaller sprocket is hurting me. Even strapped it comes up in 1st. What are you shifting at???
9.96 @ 143 stock with flies removed
Flatoutbu
posted June 26, 2006 04:41 AM
Bently: yea i was hoping for more than that but that was the worst conditions to run in. Also i need a tire in a bad way. I know the bike has alot more in it. I thought it was me but i put my 60 pound lighter cousin on it and he couldnt do anything better than a 9.89. Just to let you know he jumped on it stock and ran a 9.79. Oh yea, tuck as much as possible, i used the airshifter for the first time and thought i could dangle my legs the whole pass and it slowed me 5 mph! The Brock exhaust is great, i really recommend it.
06 Blue 14
0.29067897796631 seconds processing time
