BIKELAND > FORUMS > ZX-14.com > Thread: clicking under heavy breaking NEW TOPIC NEW POLL POST REPLY
heavenlyride
posted June 09, 2006 01:12 PM
I was riding without a helmet for a short period to detect a clicking I heard on rides. I have a click sound under heavy breaking. Not automatically but when I start to take off again.
Any thoughts?
I have to bring the bike in for the recall this next week so I want to tell them to look at it.
Bently
2012 14r In Blue and no Mods!
posted June 09, 2006 01:27 PM
Ya mine clicks as well if you hit the front lever hard as your rolling the bike around or driving at slow speeds you can hear it, it's just the front calipers getting fluid to them to apply the pads.
nabrxx
posted June 09, 2006 01:30 PM
What recall?.Is there an official recall on this bike?
heavenlyride
posted June 09, 2006 01:34 PM
Certain bikes, specific vins, have a recall on the kill switch if it tipps over. there is a thread on here regarding it. I got a letter about two days ago from Kaw on it. It is under the fairing and the bolts need to be tightened.
The recall header is call zx-14 vehicle down sensor bolt.
Hope this helps.
FasterThanStink
posted June 09, 2006 01:37 PM
Could also be the full floating rotors. Mine clicks sometimes and that's what mine is. Normal for full floaters.
That's what gets you.
nabrxx
posted June 09, 2006 01:50 PM
serius blk
posted June 09, 2006 03:22 PM
Mine makes a noise to. It sounds to me like its in the steering shaft. Its like a pop. Hard breaking and bumps and steep driveways i can hear it.
mrsantafe
posted June 09, 2006 03:38 PM
Mine made a clicking sound as well, almost a popping sound. It turned out to be the steering head bolt, It was finger tight. good luck!
2006 ZX14 gone
2004 zx10r (her race bike)
2002 ZX12 (still kicking a--)
2007 gsxr 1k (race bike)
speedgene
posted June 09, 2006 04:46 PM
Lift the bike up off the side stand. Roll the bike back and hit the front brake. That click? It's your brake pucks floating in the caliper. You always want to hear that sound. No/slight sound = stuck caliper pistons (pucks dragging) against the discs.
E-tard
Bently
posted June 09, 2006 05:05 PM
speedgene, that's exactly what I was saying.
Nixter
posted June 09, 2006 05:09 PM
Just make sure it's not a loose steering stem nut. I had mine go loose on my R1 and at first I thought it was the rotors.
2012 ZX14R - Black
Bently
posted June 09, 2006 06:10 PM
My stem nut is tight! It's the brakes
serius blk
posted June 09, 2006 06:20 PM
Thank you mrsantafe. Thats what mine sounds like. I didnt check the nut but i will now. I know its not the calipers.
Bently
posted June 09, 2006 06:25 PM
serius blk sounds like your noise is different, I would say it is you stem, mine don't make noise any time besides when hitting the brake lever.
serius blk
posted June 09, 2006 06:34 PM
Yea i know the sound your talking about. Its the calipers
Tool Man
posted June 09, 2006 07:51 PM
Maybe the loose nut holding the handle bars
It's the brake pads floating in the calipers already checked it out. It's worse sounding when you back the bike down the driveway and apply the brake. Normal no issue
The banks are failing..
The banks are failing...
Invest in Ammo
serius blk
posted June 09, 2006 08:05 PM
Thank You fellas. My steering stem nut was not very tight. I was able to tighten it and that solved the problem.
posted June 09, 2006 09:17 PM
Did you ever adjust the front and rear suspention???...How much do you weigh???
Mano 2
posted June 10, 2006 02:47 AM
I haven't taken my helment off to listen, but it sounds like the front brake light switch engaging off/on.
I have checked the screws on my roll over switch.
heavenlyride
posted June 10, 2006 06:36 AM
I believe it to be the steering stem nut. I am about to go and make sure it is tightened. You would think the dealer woudl check it at the 600 mile!
Will advise as i am about to do it now.
serius blk
posted June 10, 2006 08:55 AM
heavenlyride tighting the nut helped my problem. You have to check all the body bolts to. I happen to check my body and had already lost one bolt in the lower fairing. All the bolts on the right side of the bikes fairing were lose. I didnt believe it. I also think the wheel may not be balanced. I adjusted my front preload to stiff and i could feel the wheel on a straight flat road. It felt as if the wheel wasnt balanced. You cant feel it with the front shocks soft. Im debating if i should pull it and have it checked. I read the new rim helps with the balancing.
Nixter
posted June 10, 2006 10:41 AM
On the R1 it was the nut under the triple clamp. You had to remove the top clamp and there was 2 locknuts with a rubber washer between them. The rubber washer wouldn't allow the top nut to torque up enough, but if you shit can it it worked fine. Not sure how the 14 is, mine has stayed tight so far.
2012 ZX14R - Black
heavenlyride
posted June 10, 2006 12:23 PM
i had noise on the stop and the start. dealer time. it does not handle like head is loose. i hear the brake switch and the rotor noise. My Mille has that noise of floating brakes.
I will advise after he takes a look.
0.22324800491333 seconds processing time
