BIKELAND > FORUMS > ZX-14.com > Thread: just ordered halibars. Input please! NEW TOPIC NEW POLL POST REPLY
200mphclub
posted June 08, 2006 09:14 PM
Anyone have the handle bar risers? I just ordered them. Can some one tell me what they like about them?
QWICKR
posted June 08, 2006 09:44 PM
Where did you order them from?
YES... Her ZX-14 !!!
200mphclub
posted June 08, 2006 10:14 PM
helibars.com $79.00 10 min install
dbeadling
posted June 09, 2006 08:20 AM
put them on 2 days ago....much improved riding position for a old guy with a back that does not like to bend.easy to install . 4 bolts... 6mm .I am 5 foot 11....also got a double bubble on the way. I am really pleased with the bars now that they are up and back a little farther.it does not sound like much but it does make the bike more comfortable for me. the risers are first rate and blend right in with the bike. tighten up the bolts to 12 foot lbs. and enjoy.
cls
posted June 09, 2006 08:59 AM
dbeadling,
What's your height, and are there different options for the bars, as far as rise, distance to you, etc.?
Thanks.
TeamSpeed
posted June 09, 2006 09:42 AM
I put mine on too, better for me as well, I am 5'9".
Did you get a smoked double buble, and from where? I think I want a smoked ws, and most likely a double bubble.
marco383
posted June 09, 2006 10:46 AM
Another old guy, this time with bad shoulders, a product of fifty (!) years of bench pressing. The Helis do noticeably improve my ability to stay in the saddle.
Stalwart
posted June 09, 2006 11:07 AM
I am also very happy with this purchase, at 6'2" I probably need them less than some, but I didn't like the pressure on my wrists below 50 mph. They also moved me away from my tank-bag.
Stuart
Ridin' the Trump train.
posted June 09, 2006 11:25 AM
Let me know if your interested in something else.... 3" higher, and 2 " back..
nice looking product the heli's though!.
TeamSpeed
posted June 09, 2006 11:59 AM
I would like more adjustment than what the heli's gave me, but the limiting factor in their design were the two throttle cables coming within a 1/4" of the fairing when turned completely to the left.
If there was a way to readjust the throttle cable attachment, then there more might be more wiggle room for the heli design.
FasterThanStink
posted June 09, 2006 12:09 PM
Do tell! Where did you get the DB windscreen. I am looking for one and nobody has them. Dark smoke please.
That's what gets you.
cls
posted June 09, 2006 12:15 PM
5'9" to 6'2", I see (Sorry I missed it in the skim of your original post.). Does it allow you to roll the brake/clutch levers any further down? If so, I believe I'm a customer.
posted June 09, 2006 12:18 PM
the throttle has eliptical mount, if you held the 2 brackets that go on the bars together, it is about 1/16 inch from being perfectly round,
I ground off the little peg, which allowed me turn the whole throttle assembly, giving more clearance with my clip on mods.
The heli set up is the simplist bolt on mod, and about as good as a bolt on improvisation will get.
My clip ons took about 4 hrs to install, lots of modifiing parts, and making new resvoir brackets, and I had tyo lower thr frt suspension 1" to install them
It was not a simple bolt on ......
If simple install is what your after, and are satisfied with the new bar location then I advise helibars be the route!
speedgene
posted June 09, 2006 04:58 PM
Aye dubious, yours is more of what I'm looking for.
I have the Heli's on now, but I'd like to try the bars you have on yours. Who makes them? TY.
What I really had in mind with the Heli's is bolt a plate across, drill a couple holes for the perches, and a bar that sets me more upright. I'm willing to take a 2nd strike before 3's the charm.
E-tard
roknroe
posted June 09, 2006 05:08 PM
I'm 6 feet and they are nice for me. A very simple and cheap fix.
MasterBlaster
posted June 09, 2006 05:20 PM
[ the throttle has eliptical mount, if you held the 2 brackets that go on the bars together, it is about 1/16 inch from being perfectly round,
I am intrested also. I want to prove to a couple of disbelievers that the 14 with the right setup will make an all around do everything bike. Track, twisties, and sport touring, and all the same day if you want.....TB
PapaBoomBoom
posted June 09, 2006 07:51 PM
I too installed Heli Bar risers (not actual bars but risers) Install is so quick that I will leave them off for quick daily stuff and put them on for longer trips. Very nicely finished and made with tight tolerances. No cable stuff to deal with either. Pop em on and go. Remember to use the supplied bolts and torque to 12 ft lbs.
posted June 10, 2006 01:09 AM        Edited By: dubious on 10 Jun 2006 02:14
Use these ones:
http://www.spieglerusa.com/cfm/clipon.cfm?type=offset
The ones on the top of the page, I have already picked the 50 mm size for you ... this is the diameter of the fork uppers on the zx14.
I just wrote a 2 page instruction but lost it all while inputing links!
Fuck.
anyway I type slow soooo...
If you have more questions and are serious PM me, I would advise a phone call at that point we ca exchange phone numbers... I can provide instructions and save you alot of time.
It in no way is a direct bolt on !
Definately should phone me before you even order parts!
Heres picks http://www.bikeland.org/board/viewthread.php?FID=27&TID=24179&set_time=
0.24724698066711 seconds processing time
