BIKELAND > FORUMS > ZX-14.com > Thread: Damn engine heat!! NEW TOPIC NEW POLL POST REPLY
fastestbusaaround
I eat Fish...
posted May 31, 2006 11:17 AM        Edited By: fastestbusaaround on 31 May 2006 12:19
Damn engine heat!!
It's about 87 here today, just rode on the highway, from my office to my home (7 minute ride) at about 75MPH....damn that thing blasts a lot of heat on me while riding; right on the lower part of my legs...
I've had many bikes before this, but the only bike I can recall blasting heat on me like this, was a recent model Goldwing. The temp gauge was only showing 1 bar...no wonder...the fucking engine runs cool because all the heat vents on the rider...:P
FYYFF!!!
supra5677
posted May 31, 2006 11:20 AM
Im going to heat wrap the headers on my 12r.. On certain sports the header is 1/4 inch from the radiater.. I'm also going to add a push fan on the other side..
fastestbusaaround
I eat Fish...
posted May 31, 2006 11:22 AM
...adding a push fan to move the air out instead of in? Is that what you mean? Wrapping the headers...won't that heat the headers up more?
FYYFF!!!
Tool Man
posted May 31, 2006 11:24 AM
Come to Arizona. You will like it here, it's 102F today.
The banks are failing..
The banks are failing...
Invest in Ammo
surfinlate
posted May 31, 2006 11:32 AM
my 14 isn't as bad as my old concours...it was like a convection oven...so anything is a step up lol
posted May 31, 2006 11:36 AM
find all of this bizarre.. still maintain the ones we rode didnt do that..
I wonder if the complaints are only here cuz we pointed out the "lack" of heat.
still perplexes me.
fastestbusaaround
I eat Fish...
posted May 31, 2006 11:42 AM
The engine heat seems normal to me; it's the heat management that's the issue...it's all in the way they exhaust the heat away from the rider/bike. A classic example of this was the 03-05 FJR...riders complained about the engine heat and it seems Yamaha addressed this on the 06. I don't know why the Vegas bikes didn't exhibit these symptoms, but if you were there in January and it was say 65 or so, you wouldn't have noticed nuch heat...
FYYFF!!!
posted May 31, 2006 11:47 AM
I disagree.. was 70 one day... mid 60s the other day... here at home in those temps, esp if it's colder out the heat is more pronounced on my bikes. the 12R roasted me and it was quite convenient.. kept my warm on cold days... no noticible heat came off the 14s I rode... definetly different than my 12R...
but hey... that's just me... (oh... and Mike.. he noticed the same thing)
oh well...
fastestbusaaround
I eat Fish...
posted May 31, 2006 11:51 AM
here when its in the 60-70 range, I don't feel heat at all...on the 14
FYYFF!!!
zerMATT
posted May 31, 2006 11:54 AM        Edited By: zerMATT on 31 May 2006 13:06
Wrapping the header would contain the exhaust heat inside of the header and direct it out the exhaust pipe. The only down side to wrapping them would be that the temp of the "downstream" pipes would run hotter, and the temps coming out the end of the pipe might be a bit warmer. Overall though, you would be effectively "moving" the heat somewhere else because it can't radiate out of the header pipes. This is usually a good thing, as the header pipes would normally radiate heat right onto the engine block, and through the body work and onto the rider's legs.
Another not-so-great thing about wrapping the headers is that heat wrap generally doesn't like to get wet. So if get caught in the rain too often, it will deteriorate the quality of the wrap, causing it to break up and eventually come off. Heat wrap isn't always a good "permanent" solution for non-track vehicles.
supra5677
posted May 31, 2006 12:07 PM
the stock zx12r double fans 02-05 pull the air in, Im adding 10 inch fan from the other side to push the air..
fastestbusaaround
I eat Fish...
posted May 31, 2006 12:11 PM
I noticed on my 10R that the exhaust runs much cooler than the stock exhaust did; in fact you can put your hand on it within a minute or so of shutdown, mostly due to the lack of backpresure I assume. I would also guess that the headers are running cooler too now. So I would imagine that an aftermarket exhaust would generate less heat coming through the rad...anyone running pipes now noticed if the heat factor is less than before?
FYYFF!!!
fastestbusaaround
I eat Fish...
posted May 31, 2006 12:14 PM
This is on the 12R or a 14 you are planning to do this?
FYYFF!!!
shawnski
posted May 31, 2006 12:15 PM
last sunday was 92 degrees in houston,tx and 95 humidity. that is nasty.
correct if i am wrong guys. i noticed that the zx14 does not have any protection, plastic cover in front of header like my busa had. could that be some of the problem with heat direction to the leg.
wrongway
posted May 31, 2006 05:44 PM
Does anyone ceramic coat the headers, inside and out ? That really keeps the heat inside the headers.
Roy
zerMATT
posted May 31, 2006 06:10 PM        Edited By: zerMATT on 31 May 2006 19:15
On cars, yes. The entire exhaust system on my 944 Turbo is ceramic coated. The coating really holds in the heat, and on a turbo, more heat equals quicker spool-up time... that's a good thing
Seems that for heat containment purposes alone, ceramic coating of headers on these bikes would be a reasonable idea, I just wonder about the added heat on the underside of the bike... the lower plastic panels would likely get hotter unless you coated the entire system.
posted May 31, 2006 06:34 PM
Mine cooks my knees ...I looked where my knees are at and they are right on the grills ..If i move the 1/2 inch from the grill no more heat...If you look on the back of the grills you will see some tin foil glued to the back side ...Maybe adding more might help the problem ...
blitzkrieg
Road kill = Free lunch.
posted May 31, 2006 06:35 PM
There are those of us that understand the benefit's of wrapping the header and we do.
fastestbusaaround
I eat Fish...
posted May 31, 2006 06:43 PM
Ya...if I move the legs away from the tank slightly, heat is much less of an issue, but I don't ride that way...particularily when traveling at speeds. I'm most comfortable on any SS bike when hugging the tank with the knees...also provides for greater stability at speeds, especially in strong crosswinds. If your knees move around from air, it tends to have an effect on the side to side momentum.
FYYFF!!!
serius blk
posted May 31, 2006 07:06 PM
Well with out the wrap my 14 cooked my ankles. It was about 85 here in Galveston,Tx. Riding slow on the beach and the fan was doing its job by blowing the heat out the vents. I felt like it was cooking on my ankles. The header wrap will definitly work and makes alittle more torque. I had it on my blackbird and because i ride in the rain the wrap started to come lose in places. Mostly under the bike. The wrap on the down pipes stayed tight. I'll do it when I buy a header.
thevak
posted May 31, 2006 07:14 PM
Hmmmmmmmmmmm header rap more torque......send me some
of what your smoking........................... Yeah heat steals HP and I guess
that would effect toruqe if that's what you mean???????????
  Ignore this member    Click here to visit thevak's homepage.
posted May 31, 2006 07:26 PM
mmm.
In this case heat is good, it assists with scavenging!
Why else would anyone put that ugly mummy wrap on their machines? LOL
posted May 31, 2006 07:28 PM
Guys don't use that header wrap... It does work but looks like ass and will take half the life out of your pipes ... I have seen it happen over and over ...Take you pipes to a JET HOT Coating and have them coated inside and out ... They will look geat for years and run just as cool as header wrap...
fastestbusaaround
I eat Fish...
posted May 31, 2006 07:32 PM
Do you think that an aftermarket pipe/can will send less heat through the rad?
FYYFF!!!
posted May 31, 2006 07:36 PM
No, a properly mapped engine, with better flowing exhaust, making more power will create more combustion heat. In fact highly modified engines often need bigger rads....!
(cars) but some nikes could use bigger rads too....turbo, supercharged, all usually need more cooling
More HP = more heat everywhere
0.2540979385376 seconds processing time
