BIKELAND > FORUMS > ZX-14.com > Thread: PC installed ..... works bitchen ! NEW TOPIC NEW POLL POST REPLY
zxbob
posted May 26, 2006 03:56 AM
Well my PC showed up. I installed the map supplied by Schnitz, and talk about
about waking it up.
I did a short run with it last nite - and WOW.
Today im play'in hookie from work cause we got a 200 mile group ride, so this
will be the real test. I'll post about the ride later tonite. These PCs for the 14 are
ZX10 units, the ZX10 has the same harness as the 14 so they are NOT re-pinned.
Just install the map and go. So far the only map i've found is the one from Schnitz
running the full Muzzy. Im sure as dirrerent pipes / tuning start coming out then you'll
be seeing more maps available, but for now there is just the one.
So ........ If you have the full Muzzy - get the PC, you'll be reeeeal happy with it.
Bob
stan55
posted May 26, 2006 04:47 AM
Bob, How much did you pay for the powercommander?
Stan
Ozzy
need guberment cheese
posted May 26, 2006 04:53 AM
thought I saw a post showing which pins had to be switched to make the 10r pc fit the 14?
zxlnt
posted May 26, 2006 05:32 AM
Ozzy I saw that as well. In fact I believe it was in Brock Davidsons Dragbike.com post. There was a piece of paper with a Power Commander Wiring Pin Out on it..
Tool Man
posted May 26, 2006 08:26 AM        Edited By: Tool Man on 26 May 2006 09:27
ZX Let us know ASAP about PC A little off topic How do you like the Pilot Powers on the 14?? Will be ordering new set SOON. The BT 14s arer almost shot at 1800mi
The banks are failing..
The banks are failing...
Invest in Ammo
TheVak
posted May 26, 2006 08:47 AM
I have my Muzzy and Power Commander III USB sitting on my porch Grrrrrrrrrr
waiting for four new exhuast crush gaskets. And no Im not turning them around
lol.
  Ignore this member    Click here to visit thevak's homepage.
stan55
posted May 26, 2006 08:50 AM
Tool Man,
I take it, that you ride hard..... I could tell you that I love my Pilot Powers on my 12r.... By the way Michelin is coming out with a new Pilot Powers. They are called Pilot Powers 2CT, they are 20% softer on the sides... With a Max lean angle of 53 degrees. The older one's was max lean angle of 51 degrees.
Flatoutbu
posted May 26, 2006 08:56 AM
Talked to schnitz 2 days ago...said a new map will be coming out in a week or two. They have one for a stock bike and another for the full muzzy with MR9 but, this still works great with pump gas if your wondering.
06 Blue 14
9.008 at 153mph @ 195 suited
TJ
posted May 27, 2006 08:56 AM
Bob, where did you put the PC unit? Any pics of the install?
vegasdude
posted May 27, 2006 09:05 AM
http://www.dragbike.com/dbnews/anmviewer.asp?a=2079&z=2
Scroll down and look at the pics
TJ
posted May 27, 2006 09:08 AM
0.22303295135498 seconds processing time
