BIKELAND > FORUMS > ZX-14.com > Thread: Removal of Middle Fairing NEW TOPIC NEW POLL POST REPLY
marco383
posted May 19, 2006 04:39 AM
OK, having now given up on getting the exhaust flange nuts on through the openings in the middle fairings, I'm ready to remove the damn things. Question: what size/type are the fasteners that hold the fairing to the inner panels? I can't quite see what they are, and have tried about every tool in the box using the braille method without success.
Why the hell do the Japs insist on making sportbike fairings so complex? I could drop the fairings on my Ducati 916 in about four minutes flat. Of course, that was the only good thing about that bike.
TJ
posted May 19, 2006 07:05 AM
If you are talking about the front inside cowling (under headlight and connects side panels to upper), it is a 4mm hex.
tslewisz
posted May 19, 2006 07:51 AM
What's the trick to getting the lowers off? Seems like they "snap" into the mids along with being secured by screws.
TJ
posted May 19, 2006 11:56 AM
After removing the fasteners, lift the bottom outwards.
0.36166501045227 seconds processing time
