Drowland
posted February 07, 2006 05:51 PM
I got the latest Info!
Got it straight off www.zx14.net
Engine Type: 4-Stroke, 4-Cylinder, Liquid-Cooled, DOHC, 4 Valve Cylinder Head
Displacement: 1352 cc
Bore & Stroke 84.0 x 61.0 mm
Maximum Torque: 113.5 lb-ft / 7,500 rpm
Compression Ratio: 12.0:1
Fuel Injection: DFI with Mikuni 44mm Throttle Bodies (4)
Ignition: TCBI with Digital Advance
Transmission: 6-Speed
Final Drive: X-Ring Chain
Rake/Trail: 23 degrees / 94 mm.
Front Wheel Travel: 4.6 in.
Rear Wheel Travel: 4.8 in.
Front Tire Size: 120/70 ZR17
Rear Tire Size: 190/50 ZR17
Wheelbase: 57.5 in.
Overall Height: 46 in.
Overall Length: 85.4 in.
Overall Width: 29.9 in.
Front Suspension: 43 mm Inverted Cartridge Fork with Adjustable
Preload, Stepless Rebound and Compression Damping
Rear Suspension: Uni-Trak with Adjustable Preload, Stepless
Rebound and Compression Damping, Ride Height
Front Brake Type: Dual Semi-Floating Petal Discs with 4-Piston Calipers
Rear Brake Type: Single Petal Disc
Fuel Tank Capacity: 5.8 gal.
Seat Height: 31.5 in.
Dry Weight: 474 lbs.
Color: Passion Red, Ebony, Candy Thunder Blue
MSRP: $11,499
posted February 07, 2006 05:54 PM
yer late...
it's already here...
http://www.bikeland.org/board/viewthread.php?FID=27&TID=21614&set_time=
Reaper
posted February 08, 2006 03:29 AM
According to the post time he posted his info in the same minute as yours =). Not that I care, as info is good info at this time no matter who posts it from where.
Reaper
2000 ZZR1100
Katie: 2006 ZX-14.. 186.69HP 110.68ftlb,
Ti-Force Twin High mount Slip-ons, Hyperpro Steering Damper, Sato rearsets, Carbon Fibre Lowers, lower rear wing, Tank Pad, Hugger, Ohlins Road and Track Rear Shock, HID low beam, Sato Rearsets, ASV Levers, Goodridge Carbo-Line Braided front and rear Brake lines, Galfer Braided Clutch line, ZX-10 Front Fender, EK ZZZ Drive chain, Driven rear sprocket, Pipercross Race filter, Powercommander, Secondary Butterflys removed
zxfingyz
posted February 08, 2006 11:57 AM
So how does that work Fish? You had street date or something? Contractually held to a time on posting the info?
posted February 08, 2006 12:01 PM
Info was emailed to me...
We get the info and then pass it along to you!
Reaper... we like to post the original PDFs so that people cant suggest it's just someone typing info out..
that way you get to see what we get to see!
Reaper
posted February 08, 2006 02:32 PM
Ahhhhh I see, anyway I did click on the link but it didn't down load, probably my computer though might take to it with a sledge hammer to teach it some respect =)
Reaper
2000 ZZR1100
