BIKELAND > FORUMS > BIKE CHAT > Thread: need some fork diameters NEW TOPIC NEW POLL POST REPLY
Eric_The_Jew
posted November 09, 2012 05:26 AM
Looking to do a fork upgrade on my '01 gsxr1000, and would like to use some newer model Showa components, such as from a newer GSXR, Ninja zx10 or zx6, CBR, etc. I would like to use the Big Piston Fork if it will work.
If anyone has the ability to get some measurements, it would be greatly appreciated. I need to know:
the fork tube outside diameter at the top triple clamp
the fork tube outside diameter at the bottom triple clamp
the overall length of the fork from the top of the fork tube to the axle centerline
I would like to use a fork with the same measurements as my stock triples (50mm/54mm) to make the install as streamlined as possible.
(I know the bottom triple clamp measurement is pretty tough to get with the forks installed, so if you can't measure all these dimensions, just tell the numbers you got and what bike it was from.)
d4lh.gif" border=0>
0.23617005348206 seconds processing time
