tdiv135
posted March 03, 2008 08:59 PM
gas prob
on my 02 954 gas pours out the breather hose on the tank any suggestions why
posted March 03, 2008 09:01 PM
what do you mean "pours out"?
tdiv135
posted March 03, 2008 09:22 PM
it comes out of the breather hose like it was a gas line
posted March 04, 2008 06:20 PM
under what circumstances... be more specific or no one here will be able to help you!
tdiv135
posted March 04, 2008 09:11 PM
gas pours out of the breather hose on the gas tank when its running when its not and even when the tank is off the bike it pours out till the tank is empty
posted March 05, 2008 04:54 AM
what happens if you open the gas cap?
tdiv135
posted March 05, 2008 06:39 AM
the gas still comes out
aliveagain
posted March 05, 2008 08:02 AM
Once it picks up a suction and flows,opening the cap won't do anything.I'ld look at the cap to make sure the vent is working to stop the siphon before it begins.
jeff martin
Pro (closed)
jamming
posted March 05, 2008 09:15 PM
Plugged return vent line !
i play with boats my wife plays with my dingy.
posted March 06, 2008 01:29 PM
have you tried using a match?
tdiv135
posted March 06, 2008 11:09 PM
not yet but close
Sticks_n_Stones
posted March 10, 2008 04:26 PM
Edited By: Sticks_n_Stones on 10 Mar 2008 17:28
first thing first: your vent line is supposed to be open to the tank right next to the gas cap. On dirt bikes it is literally IN the gas cap (the rubber hose you route down by your forks). Should not be possible for gas to come out unless the tank is completely full. You must have it hooked to the return or supply line to the carbs. (it is carbs, right?). Dont know how the 954 tank setup is, but most have the vent line a hard line that ends about the center of the tank where the seat meets it, where your rubber line hooks up to it.
Good luck
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Sticks_n_Stones
posted March 12, 2008 01:18 PM
Bikes too new for this, but just maybe... if your vent line is routed internally to the top of the tank, it could have gotten corroded through. Long shot though.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
tdiv135
posted March 12, 2008 05:05 PM
that could be it i put fuel injector cleaner in it and the next day thats when i had this problem
posted March 12, 2008 05:08 PM
is there anything else you havent told us
