BIKELAND > FORUMS > BIKE CHAT > Thread: ZX14 STUCK IN 6TH GEAR NEW TOPIC NEW POLL POST REPLY
tccycles84
posted February 24, 2008 08:19 PM
this is what happen. I rolled out from the shop on Saturday for a good ride home. before i left the shop i turned onthe air shifter for a rocket ride out from the shop
i rolled inthe throttle then pinned it i felt the tire spin then catch so i hit the button 1 time then then i had to roll out that swhen i saw that the gear select said 6th gear?
so i tryed to down shift it would not. i stop then tried it still would not shift . i did get it to pulloff in 6th gear so i rode on home not good on the clutch but i made it home i turn the bike off and it shifted down from 6th no trouble. i set the bike up on a stand and started it ran it through the gears no trouble no noises. off the stand and out to the lake road for a hole shot and on the air shifter no trouble. but this does make me wonder what i may have bent. has this happened to anyone
W.O.F.the only way to ride in Germany and now LA 189mph
Sticks_n_Stones
posted February 26, 2008 11:29 AM
Jeesus no one has responded to this post yet???
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
aliveagain
posted February 26, 2008 12:22 PM
You've said it shifted down after this scare,have you taken it out to see if it'll run right without the air shifter connected?Curious to see if your solenoid is leaking by and is why you couldn't down shift, due to it still being activated.I think that might also explain why you ended up in 6th gear even though you only hit the button once.I might try to disconnect the line going to the shift solenoid and see what happens.Better yet,put a 1/8" gage on the pressure regulator first and see where the pressure sits.Also double check the direction of flow through the regulator and actuator.
0.29511594772339 seconds processing time
