DB
posted February 12, 2008 06:31 PM
2 bikes in a truck
What is the best way to tie-down two sportbikes in the back of a truck????
Dan
04 ZX10r (Track only)
08 Concours14
MAXIMUS
posted February 13, 2008 08:35 AM
M/C tie downs,
Sticks_n_Stones
posted February 13, 2008 01:00 PM
Edited By: Sticks_n_Stones on 13 Feb 2008 13:18
BAhahahahaha! Funny man!
Hard to do DB, but you need a full size to start with, and the way I've done it was: strap first one down just off center, lean it towards the side as you tighten the straps. Wheel other bike in, leaning bike so that tires are as close as possible to other bikes tires then tie it down in the lean.
Critical step! Cut two 2x6 or 2x8's to fit between BOTH front and rear tires of each bike. It will keep them from sliding together when you hit a bump.
I've done that for numerous around town drives, but never for more than a few highway miles. They never moved an inch either. Just keep the fairings at least a couple inches away from each other to be sure. And dont forget the wood blocks! I once used a 5' long 2x16 between the tires when I was going to be driving down a dirt road, would recommend that so that the blocks dont bounce out - though they never did, usually got wedged tight as the tires started to slide together during the drive.
Some big trucks can fit them together without leaning, but not the newer trucks I've used. Seems the beds got slightly narrower on the newer trucks.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
DB
posted February 13, 2008 01:24 PM
Thanks, especially to Max!!
Dan
08 Concours14
Sticks_n_Stones
posted February 14, 2008 06:59 AM
Edited By: Sticks_n_Stones on 14 Feb 2008 07:05
Hey DB, I spent 10 minutes making that drawing and you thank Max? jeez...
Well, regardless, here is a bigger pic of what I was talking about:
OK, make that 30 minutes so far .... someone better use this damn idea now! lol
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
DB
posted February 14, 2008 07:22 AM
Sticks, I was being sarcastic to Max as we all know you have to use tiedowns.
My problem is not fitting 2 bikes in the bed but once you have 2 bikes in the bed how do you tie them down since both bikes are blocking one of the other bikes tiedown points.
Oh, btw sticks, that's a real nice pic!!!!!
Dan
08 Concours14
Sticks_n_Stones
posted February 14, 2008 09:13 AM
Edited By: Sticks_n_Stones on 14 Feb 2008 09:21
handle bar to handle bar.
actually, triple clamp to triple clamp, fairings shouldnt be an issue for the the connector.
when you initially lean the first bike, I always tied the tie down temporarily to the end of the clip-on, that way the other bike can nose under that tie down to get into place. then remove the temp tie down. Every set of bikes is different, with different fairings etc. so good luck!
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
warbird
posted February 15, 2008 04:58 PM
Buy two Baxley bike chocks, set them in the bed of your truck, roll the bikes in the chocks,GENTLY attach tie downs pulling down and forward. No hassles, no worries. When you get where you are going, take the bikes out, take the chocks out and use them on the ground to hold your bikes.
http://www.baxleycompanies.com/index.html
I'd Rather Be Roadracing.
warbird
posted February 15, 2008 05:00 PM
warbird
posted February 15, 2008 05:01 PM
warbird
posted February 15, 2008 05:03 PM
DB
posted February 15, 2008 07:01 PM
Warbird, so with the baxley chock I don't need to tiedown with the handlebars thus collapsing the forks? I still need to be able to strap both bikes though.
Dan
08 Concours14
Sticks_n_Stones
posted February 16, 2008 09:34 AM
Edited By: Sticks_n_Stones on 16 Feb 2008 09:36
You always have to tie down the handlebars DB. Just that with those you dont have to fully compress the forks, just give it a decent tension. The only issue is whether you have enough room BETWEEN the wheel wells to fit both bikes without scraping your fairings on the wheel wells or each other. 2000 on up Chevy's there isnt quite enough room for a zx14 and TL1000R, or that TL1000R and a 636. Tried both. Which is why I came up with the bike lean thing. If you got another way let me know!
Oh yeah, I saw those bike stands at the Seattle Bike Show, I believe they are $200 a piece? Nice, but thats alot of dough!
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted February 17, 2008 05:49 PM
great idea with the chocks
warbird
posted February 17, 2008 06:38 PM
They are really useful for all kinds of applications. For instance.............puting your bike up on a rear pitbull stand. Just roll the bike into the chock.............and there it stands. No holding the bike with one hand and balancing it while you roll the stand under the back with the other hand. Just slide the stand under the bike, and then pull the bike out of the chock with the stand handle off the ground a few inches. You can leave the front in the chock or slide it out and use your front stand to clean on your wheels. No balancing act.............
