BIKELAND > FORUMS > BIKE CHAT > Thread: 2008 Busa vs 2008 ZX-14 on the dyno NEW TOPIC NEW POLL POST REPLY
rotts4u
posted November 18, 2007 04:06 PM
The waiting is over. Today I was present at the local dyno shop where both bikes made it in for a completely unbiased shootout on the dyno. Both bike had nearly identical mileage. 294 on one vs 285 on the ZX-14. Both had been heat cycled several times and had oil changes with 10W-40 oil in both. They also both had 100% pump, 93 octane gas and the rear tire pressure was checked and were within 2 psi. Also both had adjusted chains and they were properly lubed. In other words we did everything possible to ensure the test was as fair as possible.
I own the 2008 Busa and the dyno operator/owner of Dyno Masters in Chattanooga Tn. Mark Hromi owned the ZX-14. Our intentions were to test both bikes stock and run them 3-5 pulls each and then pull them off the dyno and install a Power Commander and map each one at 100% on the DJ250I machine using the Tuning link software and then run them both again for HP/Torque.
The Busa power commander (2007 GSXR1000 PC actually) plugged in just fine and all was well but for some reason the 2006 ZX-14 Power Commander caused the ZX-14 not to run at all. So we were unable to map the ZX-14 . And as you see the air fuel curve on it is really rich and no doubt a lot of power is being lost. You can see exactly at the point the air fuel goes rich the power starts to lose its upward slope and it noses over.
So the first graph is the BEST pull from the 14 and the Busa. And the second run is the before and after on the busa after mapping it with the stock exhaust etc.
I know all the Kawi guys are going to cry foul but personally I dont know what else we could have done to make this fair. Same day, same dyno, back to back runs on a great day with pump gas etc. The dyno is a VERY well maintained machine and the numbers on the busa seem to be very close to the others I have seen reported from Dynojet etc when everybody uses SAE reporting not STD. Also both bikes were bought locally off the dealer floor. These were not sent to me from Kawasaki or Suzuki, these are RETAIL bikes.
Discuss !!
smokinzx14
posted November 19, 2007 03:28 PM
Old post olds news move along please ....
0.28542184829712 seconds processing time
