BIKELAND > FORUMS > BIKE CHAT > Thread: Gixer 6 NEW TOPIC NEW POLL POST REPLY
sagot
posted May 01, 2007 12:18 PM
Gixer 6
Road a brand new 2006 GSXR 600 on the weekend. It is an exelent bike in most ways but it doesn't seem to turn in as easly as older GSXR,s (2002,2003). Has something changed?
posted May 01, 2007 06:29 PM
You got older?
sagot
posted May 02, 2007 08:36 AM
Dear stupid.
Don't snap yer throttle open at low RPM. It's hard on a new engine. Especially a big V twin or single. I puts a lot of load on the crank bearings when the oil pressure is low!
sagot
posted May 02, 2007 08:37 AM        Edited By: sagot on 2 May 2007 09:38
OK now say somthing mean back at me.
frEEk
posted May 02, 2007 11:50 AM
Dear stupid.
now that's a stupid thing to say to fish. he's never had an engine at low RPM. never ever. he uses an ourboard starter motor to bring it up to 5000 before he even starts it. man, don't u know _anything_?
sagot
posted May 02, 2007 03:38 PM        Edited By: sagot on 2 May 2007 16:51
From another source: gtecperformance.co.uk
Ever noticed that Ducati recommend that a service agent adjusts' the chain on their models?
Most important on the single sided swing arm models! The reason is simple, the pinch bolts should be torqued up.
Over-tighten the bolts and it compresses the rear wheel bearing causing pre-load, this in turn causes the bearing to overheat with obvious disastrous consequences! When your Ducati is serviced the axle should be removed, cleaned, inspected and re-greased.
This is a VERY important safety issue!
worm~hole
posted May 03, 2007 03:26 PM
...thanks
posted May 05, 2007 07:46 PM
twilight zone thread here
anyway.....the 600RR is the bike to have for turning "fast"
sagot
posted May 09, 2007 08:09 AM
Hmmm maby I should check the tire presure! Ha!
F_Sik
posted May 15, 2007 07:22 AM
heh heh heh
As long as y'all don't have any kryptonite/I'm gonna be alright.
  Ignore this member    Click here to send F_Sik an AIM message.
posted May 18, 2007 08:44 PM
I cover my tach on the 600 from 0-8000 rpm. And when I can't see the tach needle means I'm not running the motor high enough.
track riding is the chiznit, but the silly chicks dig the ZX14~
0.25249695777893 seconds processing time
