BIKELAND > FORUMS > BIKE CHAT > Thread: 1979 KZ1300 Turbo NEW TOPIC NEW POLL POST REPLY
posted August 10, 2006 06:21 AM
1979 KZ1300 Turbo
Picked up my winter project!
The bike was in storage for quite a while, and unfortunately, the roof leaked. Ah well, that just makes it a real project!
My plans:
Functionality: replace fluids, gaskets, cables as required. Flush the fuel system, rebuild the carb.
Appearance: pull the exhaust, clean and ceramic coat. Clean and repaint engine cases.
Pull wheels, clean and inspect bearings (should be ok not that high of mileage).
Is this going to be a frame up resto? Dunno at this point.
Overall, the bike is in great shape. Most of the work is cosmetic, and I'm hoping that, with the fluids replaced, a new intake gasket and a fresh battery in it, I can get it fired today. That will let me check out the turbo. I anticipate it'll be spring before the wheels roll again. Will need a suspension rebuild, brake rebuild first. And the clutch will need work.
GUNNER
posted August 10, 2006 06:41 AM
I want it!!!!!!!!!!!!!!!!!!!!!!!!!! Very rare indeed
harryzx-12
posted August 10, 2006 09:25 AM
Cool bike. They had weak cranks didn't they?
posted August 10, 2006 11:53 AM
Hi Harry,
Not sure! This one has stood up to 26 lbs of boost, so you tell me!
Today was tear down day.
Pulled the seat, tank and turbo exhaust off to get to things. Replaced the battery, changed the oil and filter, and lubed up the throttle and clutch cables. Bled the brakes (bone dry, tiny tumbleweeds rolling around in the reservoir!) and got the front brakes to come back pretty solid. All this is just preliminary flushes and checks, there will be a second round of fluid flushes and checks.
Things to do:
Flush and fill radiator, check for leaks.
Flush and fill water injection tank, check for leaks
Get that gas tank treatment for rust, flush, fill, check for leaks.
Engine rolls over (jumped the starter solenoid). No clunk clunk sounds! Will change oil and filter a second time after initial fire and run.
The good part is that there's a lot of NOS stock available on the internet. I can get any cover or gasket set I need. Heck, even the local dealership still had the oil filters.
What it looks like now:
Keep that puppy charging!
Always bag and tag!
harryzx-12
posted August 10, 2006 01:12 PM
I was thinking about getting one when i was stationed in england (quite a few years ago) but was advised not to as i was told the cranks were weak. If that bike was holding up to boost what i was told must be bullshit.
I was looking at all the kawasaki 2 strokes when i was on the isle of mann. 250,500 &750cc's all triples.
I love the way 6 cylinder bikes sound. Had a benelli 6 pass by several times at glen helen IOM
http://www.vintagebike.co.uk/Bike%20Directories/Benelli%20Bikes/images/Bennelli_jpg.jpg
posted August 10, 2006 02:31 PM
It *is* a plain bearing crank...So oil flow is critical, ya know?
Stalwart is mailing me the key, once I get that I'll check out the ignition. These boogers are known for really weak coils, so I'm anticipating a fresh set.
frEEk
posted August 11, 2006 10:29 AM
that is freakin' awesome swft. i'm lovin' the very different exhaust system. unique indeed.
GUNNER
posted August 11, 2006 10:33 AM
Old style 80s vintage Mr. Turbo from the Ted Hoffmeister days.
outrider
posted August 11, 2006 04:22 PM
Ahhh yes. A nice quiet family bike.
Have fun and check the turbo bearing.
posted August 11, 2006 05:30 PM
You know it guys! I cranked it long enough to turn off the oil light today when I got home. Gonna run out tomorrow morning and get some new gas line for it. Might hear this puppy fire up tomorrow.
posted August 11, 2006 08:06 PM
Well, I got impatient and went out and got the hose tonite. No such luck on getting it fired. The carb is gonna have to come off for a rebuild, no doubt. Then it's the turbo. Doesn't spin all that freely, but no funky rubs or anything...How freely should it spin?
posted August 13, 2006 12:02 PM
Talked with Stalwart, think I'm gonna go with fuel injection, ditch the snomobile carb...
Autronic makes a nice unit:
http://www.autronic.com/page_files/smc_kit.htm
They have several models, the SMC is gonna do everything I need.
GUNNER
posted August 14, 2006 01:18 PM
Dude that bike will have a RayJay FF40 turbo most likely. Two Words........Ditch it!!!! Get a garrett unit and you'll be a ton better off. It's a very old and out dated compressor by todays standards. It should spin free and have some shaft wobble to it, BUT not enough to rub either housing.
posted August 15, 2006 08:30 AM
No shaft wobble, but sure doesn't spin freely. Question is, how much do I want to invest in this project? This could rapidly get silly. Then again, if getting it running is gonna be a couple grand, and a couple grand more gets it running *RIGHT* ... Well...
GUNNER
posted August 15, 2006 08:49 AM
The unit has to have some wobble. The shaft floats in the bearing and the bearing floats in the center section. It's designed that way and when everything is floating properly it moves a little from side to side by your finger tips.
posted August 15, 2006 10:51 AM
Could be pretty gummed up, don'tcha know.
GUNNER
posted August 15, 2006 11:23 AM
YES! It's easy to take apart and clean.................Impellar has a left thread on the compressor side. Use 12 point to hold shaft on the Turbin side and clean that bitch up. Bearing is just about 40 bucks. Or at least they use to be that. I probably still have a few bearings laying around here somehwere
posted August 15, 2006 08:58 PM
Cool. Thanks for the advice and info! What do ya think bout that Autronics unit?
GUNNER
posted August 18, 2006 12:21 PM
Engine management is as good as the amount of cash you want to spend. There are many things to take into account. I retroed EFI on my zx11 turbo project. AND like I learned the hard way with my radios this past winter AGAIN! ECUs don't like dirty power around them and finding a good isolated spot to put one on a bike that wasn't designed for that in the first place can be very challenging. I would probably just stick with the carb or a nice easy cheap fun project could turn into a nightmare. Sort of keep the bike true to the era.
blitzkrieg
Road kill = Free lunch.
posted August 18, 2006 08:40 PM        Edited By: blitzkrieg on 18 Aug 2006 21:41
Very cool project and it definitely looks like you've got a good base to build on.
Thats a bike I don't know shit about, so I'm going to sit back and learn as you go.
Edit: BTW - cool dog.
posted August 20, 2006 12:40 PM
Got the replacement starter solenoid in yesterday, replaced it, much better!
Really got tired of using a pair of pliers and jumping across the solenoids.
Next project is to replace the coils with some aftermarket units. They are known to be weak, and you can swap them out for some healthy accell units.
posted August 20, 2006 12:44 PM
Holy crap...Want to know how little is posted about KZ1300s??
My bikeland post came up on the second page of searches for 'kz1300'
Stalwart
posted September 02, 2006 09:05 AM
And it went to a good home for a song . . .
Stuart
Ridin' the Trump train.
posted September 03, 2006 07:43 PM
Picked up a couple sets of NGK plugs for it. When I get it to fire and run, will put a set of plugs through it, yank them, then adjust heat ranges as needed to compensate for rich/lean condition.
Stalwart
posted September 04, 2006 01:42 PM
Just wait 'till you hear that old girl growl, and you'll probably mess the front of your shorts. Don't forget the box of Kleenex on the bedside table . . . :P
Stuart
0.23173904418945 seconds processing time
