BIKELAND > FORUMS > BIKE CHAT > Thread: 2007 Yamaha WR450F NEW TOPIC NEW POLL POST REPLY
posted August 05, 2006 05:46 AM
2007 Yamaha WR450F
2007 Yamaha WR450F
A YZ-bred advanced aluminum frame, carefully engineered from castings, forgings and extrusions—enhances handling while retaining Yamaha feel and characteristics.
Now there's even more controllable power flowing from the five-titanium valve, 11,000 rpm engine, and it starts with the push.
Digital enduro computer offers speedometer, clock, tripmeter, etc., in basic mode—or use management functions such as timer, distance compensating tripmeter, average speed.
The WR450F is green sticker approved for California.
ALL NEW FOR 2007:
ENGINE:
449cc liquid-cooled, DOHC four-stroke with five titanium valves delivers more broad power than ever. New engine has high over-rev capacity and crisp, linear throttle response.
Changing the cylinder mounting angle to a more vertical position in the new frame provides excellent overall machine balance by placing more weight to the center..
Revised camshafts, carburetion, intake ports, exhaust, etc., all work together to produce an engine with even more low and mid-range power.
New crank with revised balance factor and new AC generator provides smoother running. Strong new connecting rod and piston oil-jet for increased cooling and long life.
New, dry sump lubrication system carries the oil reservoir inside the engine cases, for excellent mass centralization and simplified plumbing.
39mm Keihin FCR flat-slide carburetor with throttle position sensor (TPS) produces ultra-precise fuel/air mixing and quick throttle response.
New "no tools" airbox adopts hinge-type quick-open lid. Battery rides 8mm lower than before for improved handling.
Digital CDI ignition system delivers more precise spark and monitors engine speed to ensure optimal timing for fast, strong response.
New, bigger radiators with reinforcements ensure maximum cooling efficiency with greater strength.
Wide-ratio five-speed transmission uses strengthened gears and YZ450F-spec multi plate clutch - good for quick-hitting power in the woods as well as eye-opening top-end power.
New kickstarter features a strengthened ratchet mechanism. The electric starting remains.
Lightweight exhaust system maximizes engine power and allows hassle-free replacement of oil filter.
Aluminum muffler with USFS-approved spark arrestor.
Works-style clutch lever features oversize barrel adjuster for easy, on-the-fly adjustability.
CHASSIS/SUSPENSION:
All-new YZ-inspired aluminum frame helps reduce weight while optimizing mass centralization. An extensively tested assembly of aluminum forgings, castings and extrusions. The new WR frame retains Yamaha handling and responsiveness.
Removable aluminum rear subframe constructed of square-section tube for reduced weight.
Fully adjustable air/oil-separate 48mm fork tubes deliver precise, fade-free handling; fork protectors provide excellent tube protection.
Tapered swingarm adopts YZ-style linkage for controlled, compliant rear suspension action. Revised axle and holders reduce weight in a critical area.
The Kayaba shock provides 12.0 inches of travel with adjusters for high- and low-speed compression damping, rebound and spring preload—and features a larger piggyback reservoir for excellent damping and fade resistance.
New, wave disc brake rotors front and rear reduce unsprung weight and provide excellent performance. Front and rear calipers with aluminum pistons deliver strong stopping power with progressive feel.
Lightweight 21-inch front and 18-inch rear Excel rims provide exceptional durability and help reduce unsprung weight for optimal suspension performance.
Premium Dunlop knobbies.
ADDITIONAL FEATURES:
Sharp new YZ-derived bodywork, new engine covers and a new thicker seat look great and is more comfortable on long rides.
ProTaper aluminum handlebar in forged triple clamp shaves weight and increases comfort.
Slim design lightweight fuel tank holds 2.1 gallons.
One-piece, high strength, plastic skid plate shaves weight and offers full protection.
Lightweight, 35-watt headlight and small LED taillight maximize visibility and draw less current.
Adjustable front brake lever.
5mm wider, super wide, footpegs are also lower for more comfort.
Cleated rear brake lever and folding shift lever tip offer superb grip and excellent durability.
Repackable aluminum muffler shaves weight.
Front wheel collar makes front wheel removal quick and easy.
posted August 09, 2006 11:01 AM
this topic is useless without pix.
lizard
Modulator
posted September 24, 2006 08:27 PM        Edited By: lizard on 24 Sep 2006 21:32
0.20984101295471 seconds processing time
