BIKELAND > FORUMS > ZX10R ZONE.com > Thread: PROJECT "BLUE BALLS" NEW TOPIC NEW POLL POST REPLY
BALTIMORE410
posted March 05, 2013 01:04 PM
2004 ZX10R
UPGRADED BRAKING SYSTEM BLAH BLAH BLAH
ok now that my braking had been addressed i want to move on to suspension
right now i have the regular stock shock and spring for the rear
and i have a 2002 suzuki hayabusa rear shock which after trying,,,actually fits under the rear
im 6 foot and fluctuate from 205-220 pounds (depends on the weather i dont work out alot but when i do i drop weight FAST thanks to the military)
i want to get my suspension to where its set up for my weight as much as possible i ride pretty aggressive on the street and if everything go right i want to do as much track days as possible
no not drag racing ROAD RACING
friend of mine gave me his shock think i should have the busa shock revalved to my weight or the stock zx10r shock done?
also what are my options for the front?
and finally where can i send my stock ohlins steering damper to get revalved
fellas the reason why im asking all of this is a few years back i owned a 2004 zx12r did the typical stupid back from iraq 2 much money in my account move
i bought a big bore kit got headwork done and slapped the biggest cams i could in it
not upgrading the brakes or suspension which ultimately sent my dumb squid newbie think i know it all ass flying over the handle bars at 185+ mph... i still ride the same i just you know trying to do things the right way eventually i will do alot of motor work but i want to address the rest of the bike before i start pouring money into the engine thought i give a little back drop before i get a million and one questions so you can kinda understand
  Ignore this member    Click here to visit BALTIMORE410's homepage.
Kneeburner
posted March 07, 2013 02:48 PM        Edited By: Kneeburner on 7 Mar 2013 22:51
I myself would not use the Hayabusa shock. You just don't know what problems you might encounter trying to mount it up. I had the rear shock rebuilt with Race Tech parts same with the front. I put new springs in the forks but Race Tech said the rear spring was ok for my weight 200lbs and did not need to be replaced. I have been very happy with the results the suspension works much better. The real key is the oil in the shock and forks its total crap from Kawi. They use high quality oil and of course a different weight. I find the suspension works more smoothly soaking up bumps and allowing me to be more confident at speed on the bike. The cost was high about 750 bucks but for me well worth it. Your 04 did not come with a steering dampner the Olin's is an aftermarket add on. If you have a competent local shop they should be able to rebuild it with Olin's parts or call Ohlin's directly and see what they have to say. I will say that when you say Ohlin's your saying expensive. I put a GPR rotorary stabilizer on and have had no problems.
Speed is just a question of money how fast do you want to go
shiphteey
posted March 16, 2013 05:27 AM
I wouldn't waste your time with the Busa Shock. I would send your shock out to Racetech or someone similar and get the shock worked for your weight and riding style. You will probably need a spring along with that, not certain. If you want to get the most out of the bike with your weight I wouldn't waste time on something that isn't tried and true. You'll be wasting time and money and probably not be happy.
A.
Gemini Motorcycles
BALTIMORE410
posted March 16, 2013 08:57 AM
got it for free tho...to make a long story short i airbrushed one of the local mc clubs shirts guy was in a jam so in exchanged he gave me his spare rear shock...thought i try it out i had 2 stock shocks sold one....ill call around this year i definitely want to do some track days
Kneeburner
posted March 18, 2013 10:03 AM        Edited By: Kneeburner on 18 Mar 2013 18:06
Free sounds good till you have to spend a lot of money to make that shock work. Hayabusa stock suspension is shit the one I had wallowed like a pig in mud till I race teched the front and rear and then the bike was a lot more fun to ride. The spring rate and valving in that shock are out in the ozone layer for a 10. It will cost you a lot of money to respring and revalve that shock. The Hayabusa is a shit load heavier than a 10. Sell the shock and use the money to race tech the 10 suspension. If you don't believe me call Race Tech and tell them your plan and see what they say.
BALTIMORE410
posted March 19, 2013 09:04 AM
puttin the shock up on ebay today....downstairs working on the body work i have a set of race fairings and a regular oem set im painting/airbrushing just finished the wheels and calipers...
TripleXZX
Living to ride
posted March 27, 2013 09:16 PM
Hey Baltimore410... I'm looking forward to seeing some pictures especially your airbrushing !
TripleXZX
2008 ZX-14 Special Edition
2008 ZX-10R
2000 ZX-12R
2001 Champions Edition R6
BALTIMORE410
posted April 06, 2013 06:30 AM
started working on the street fairing doing a sonic the hedgehog/graffiti theme NOW MIND U IM NOT THE BEST IN THE WORLD i can draw bettier than i can airbrush but im sure it will come out decent... im a virgo ill practice 1,000 times to do it right on the first try
TripleXZX
Living to ride
posted April 07, 2013 09:38 PM
Cool! Can't wait!
2008 ZX-10R
2000 ZX-12R
BALTIMORE410
posted April 10, 2013 04:27 PM
Q'2 came in today and a friend dropped off the dynotune quick shifter... sent off the head to GARTH to have some voodoo work done to it...still waiting on the rearsets to come in from japan....its coming along slowly but surely...im currently downstairs in the basement wet sanding the old clear coat off my 2 favorite arai helmets...gonna airbrush alil flake on them than reclear over top with some 2k hi gloss clear coat...give them some new life.... scott steering damper is here probably mount it up tomorrow being i dont have class...
BALTIMORE410
posted April 13, 2013 06:51 AM
finally got the gas tank back still need some bondo love....in the process of sanding it down now probably wont be done sanding until sunday
TripleXZX
Living to ride
posted April 13, 2013 06:23 PM
Thanks for the update. Remember pics later
2008 ZX-10R
2000 ZX-12R
BALTIMORE410
posted April 13, 2013 06:48 PM
been sanding all day...been goin at it so hard i forgot to eat....oops should be ready for primer tomorrow
BALTIMORE410
posted April 24, 2013 04:26 PM
had some major delays waitin on parts to come in but good news THE GAS TANK IS READY FOR GUIDE COAT finally after hours of sanding and reshaping the gas tank its ready...very intense all done by hand sanding no power/air tools all elbow grease started with a 40 grit than worked my all the way up to 800 grit trying to get it super super smooth looks great stripped the paint off the wheels was gonna paintthem gold but i think ill be painting the wheels cocaine white *flat white with a serious metallic flake*
TripleXZX
Living to ride
posted April 24, 2013 05:26 PM
Man this is sounding better n better all the time!!!
2008 ZX-10R
2000 ZX-12R
shiphteey
posted April 25, 2013 08:04 AM
When we gonna go play?
Gemini Motorcycles
TripleXZX
Living to ride
posted April 26, 2013 01:27 AM
Hey Shiphteey, I use RnR Cycles by Dulles airport!
Is that the same RnR you are with?
Do you have a 2000 ZX12r that's red? I only know 1 guy that's done those speeds and if its you that's awesome!
TripleXZX
2008 ZX-10R
2000 ZX-12R
BALTIMORE410
posted May 22, 2013 08:27 PM
http://www.youtube.com/watch?v=2QSbeN_sO1U&feature=share&list=UU3Fi-PV2WnbA4YAK-BGWVSA
FOOTAGE...
http://www.youtube.com/watch?v=4s81jaoZNAY&feature=share&list=UU3Fi-PV2WnbA4YAK-BGWVSA
http://www.youtube.com/watch?v=yG5TD3TGEvY&feature=share&list=UU3Fi-PV2WnbA4YAK-BGWVSA
BALTIMORE410
posted May 22, 2013 08:28 PM
BEEN SLINGING HELLA PAINT....GONNA WET SAND HER DOWN WITH 1200 THAN 1500 GRIT SAND PAPER TOMORROW....DO ALITTLE BIT OF AIRBRUSHING ON IT THAN SLAP ANOTHER 2-3 COATS OF CLEAR COAT ON IT AND LET IT SIT OVERNIGHT HOPEFULLY IT DONT RAIN OTHERWISE ILL JUST BE WET SANDING...
shiphteey
posted May 26, 2013 04:38 AM
TripleXZX
I can neither confirm or deny the allegations at this time your honor.
Gemini Motorcycles
Gunner
posted May 26, 2013 09:14 AM
Q'2 came in today and a friend dropped off the dynotune quick shifter... sent off the head to GARTH ..
Dead head !
BALTIMORE410
posted May 31, 2013 03:33 PM
dead head?
BALTIMORE410
posted May 31, 2013 03:38 PM
paint is finally done...
things left to do
STRENGTHEN front air ram...after i buy another one (this will be #3)
change out wheel bearings front and rear
change tires (new dunlops)
have bike dyno'd (learned my lesson from last cluster fuck ZX12R)
take bike to have suspension tweaked and tuned for my weight and riding style (aggressive street/track road course days)
bleed brakes and put fresh dot 4 fluid in
flush cooling system
change oil
i decided to wait until this winter to install the race head from garth its already june by the time i get around to putting that on having it dialed in and dyno'd it'll be july/august
all of that power upgrade crap can wait
BALTIMORE410
posted June 11, 2013 09:37 AM
flashing codes 23/24.... bike tries to crank than this nasty errrerrrerrkkkkk noise
guessing its from me yanking the old exhaust and server motor off and replacing it with hellrazors servo eliminator/ changing out the rearsets....reading up on how to clear the codes out
after that everything should fire up
BALTIMORE410
posted June 11, 2013 09:38 AM
ight i took the entire air switching vave out
when i replaced the block off plates
all the rubber tubing connected between the block off plates yanked all that shit out
but im guessin that mightb e where the problem is coming from
BIKELAND > FORUMS > ZX10R ZONE.com > Thread: PROJECT \"BLUE BALLS\" NEW TOPIC NEW POLL POST REPLY
0.35506296157837 seconds processing time
